does anyone else know of this problem, i was told putting my A/C on re-circulate would cure the issue with less pressure inside the cabin, it didn't work.
My be my rubbers need looking at.
K
LOL - brute force isn't required Alps!!; just gentle force....with the door open and the window down use your body-weight and lean back with your hands on the top of the door frame and your knee pushed up against the inside of the door holding it in place - that should be sufficient as you only need to pull the top in a couple of mm....Oh, and I like the cheap fix solution. Just a bit of brute force needed! Unfortunately, I don't have much in the way of brute force... or force in general
Now anyone who has the time to look is what I call a driverDavidT wrote:I don't think its something you can 'fix' the air pressure bows the doors out. Apparantly you can see the sky if you have time to look
