Interesting.......veeeerrrry interesting
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
S4TAN
Post by S4TAN » Sun Nov 05, 2006 9:55 pm
Hello - Now, as some of you may, or may not know (or even give a <beep>), I am a devout tinkerer when it comes to my car (N75 tweaking, N249-delete, mutilated air-boxes etc) and enjoy experimenting to try and squeeze juuuust that little bit more power/driveability out of the car, especially with regard to doing stuff that costs fack all - and, as my mechanical skills are limited to say the least, i really like doing stuff that's free AND easy......so, with that in mind:
Check this out:
http://forums.audiworld.com/a6/msgs/199693.phtml
This appeals to me, and may do to some other members (s4woody springs to mind immediately!) 8)
I'm WFH tomorrow so will be doing this as soon as i've had my morning dose of strong coffee and nicotene.... :twisted:
Also: take time to read some of the posts in the thread - there's some real bitchy bastards over on that site - well funny!...... :lol:
P.S. And before anyone chimes in about protecting the MAF from crap: READ all the posts in the thread!!!
P.P.S I totally expect a debate on this, and totally expect to get slagged off/told it's crap/stupid/dangerous/worse than genocide/planet destroying/etc blah blah.. :lol:
Deus ex machina
h8cak
RE: Interesting.......veeeerrrry interesting
Post by h8cak » Sun Nov 05, 2006 11:24 pm
Looks good! If your happy to be the test dummy I would like to know if it makes a difference?
Wide Body S4
Nige_RS4
Post by Nige_RS4 » Sun Nov 05, 2006 11:44 pm
Make sure you log the airflow before and after (not sure you can log the pressure drop???) and post the results.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
s4woody
Post by s4woody » Sun Nov 05, 2006 11:48 pm
well what do ya know..i removed that metal mesh yesterday when i dismantled my airbox and ducting to apply the reflective heat tape..
my airbox now feels much colder even at full operating temp and if it makes a diff im sure the new logs im gonna do will show me..
i was also gonna remove the plastic mesh but left that in place..
GARTH ROAD MOT CENTRE LTD
020 83353032
S4TAN
Post by S4TAN » Sun Nov 05, 2006 11:49 pm
No can do - no vagcom - arse-dyno only i'm afraid, so will have to be purely subjective results
Deus ex machina
S4TAN
Post by S4TAN » Sun Nov 05, 2006 11:53 pm
......close call.....
Deus ex machina
Dr-Al
Re: RE: Interesting.......veeeerrrry interesting
Post by Dr-Al » Mon Nov 06, 2006 12:16 am
s4woody wrote:well what do ya know..i removed that metal mesh yesterday when i dismantled my airbox and ducting to apply the reflective heat tape..
The plastic screen it there to ensure laminar flow across the sensor. Removing it runs the risk of getting turbulence at the sensor. This would be bad because it would result in incorrect output.
PS - sorry if this was mentioned in the AW links - I couldn't be bothered to read them all!
Wrecked on 9 Oct 2007: 1998 Cactus Green S4, 710N DVs, Boost gauge (in custom A-pillar/dash mounting pod), cruise control retro-fit, Parrot 3200 Colour Hands Free, RS246.com sticker
S4TAN
RE: Re: RE: Interesting.......veeeerrrry interesting
Post by S4TAN » Mon Nov 06, 2006 12:19 am
Yep - mentioned- hence "close call".... only the wire mesh gets the chop
Deus ex machina
Dr-Al
Re: RE: Re: RE: Interesting.......veeeerrrry interesting
Post by Dr-Al » Mon Nov 06, 2006 12:22 am
Read you're 'close call' post after I posted mine... Doh! :bash:
MCB
Post by MCB » Mon Nov 06, 2006 12:25 am
Interesting................Post Nice one :thumbs:
Agee good idea to leave the flow straightener, interested to see logs from this one if poss
S4B5 Avant
S4TAN
Post by S4TAN » Mon Nov 06, 2006 12:31 am
Kinda makes sense to remove it out though - that mesh sits right behind the flow straightener - so maybe it disrupts the laminar flow characteristics that the straightener has just imposed(?) - anyway; that mesh is quite large and any particles it could catch should NOT be getting through your air-filter in the first place!!
Suffice it to say: mine's coming out...
Deus ex machina
MCB
Post by MCB » Mon Nov 06, 2006 12:58 am
Could be surprised it's there
S4B5 Avant
S4TAN
Post by S4TAN » Mon Nov 06, 2006 10:37 am
Woody - have you stuck your probe in your box yet and done any tests on IAT with your hole blocked/unblocked? (snigger)
Deus ex machina
S4TAN
Post by S4TAN » Mon Nov 06, 2006 2:14 pm
Just did some further research on this - makes for some interesting reading.
A little excerpt from an Autospeed article about the reasons for removing the mesh......
"Closely woven mesh causes a major flow restriction. This is not just because of the blockage factor of the wire itself, but because of turbulence which is generated as the air squeezes through the small openings."
And another excerpt from the results of the tests they did.......
"Well, there sure was an improvement...."
"1. The greatest flow restriction of the intake system was occurring between the exit of the airbox and the turbo.
2. The airflow meter was causing the majority of this restriction.
3. Removing the airflow meter screen made a major improvement."
Apparently it's all about pressure ratios and reducing the pressure drop at the turbos (and eliminating "negative boost") - anyway, i've taken my mesh out........ :wink:
Deus ex machina
CliveH
Post by CliveH » Mon Nov 06, 2006 3:56 pm
S4TAN wrote: anyway, i've taken my mesh out........ :wink:
and the result...? :bigwave:
Clive
Users browsing this forum: Majestic-12 [Bot] and 70 guests
