Headlamp washers NOT working
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
h8cak
Post by h8cak » Wed Oct 11, 2006 10:27 pm
My headlight washers dont work?? Is there anything which is common that i should be looking at?
Cheers Guys/Gals
ChipHazzard
RE: Headlamp washers NOT working
Post by ChipHazzard » Wed Oct 11, 2006 10:36 pm
Are you checking these with the lights on ?? they work on water pressure I believe one of the common problems is due to split pipes
It might be worth looking under the car when you try to use them to see if you get a spray out under the car
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
h8cak
Post by h8cak » Wed Oct 11, 2006 11:28 pm
Will try tomorrow. Cheers fella
Wide Body S4
Dippy
Post by Dippy » Thu Oct 12, 2006 12:50 pm
Pump failure is common. Defective part that Audi kindly never bothered replacing, even for the last B5 S4s off the line...:(
2001 Silver S4 Avant
>RS4<
Post by >RS4< » Thu Oct 12, 2006 12:57 pm
And where exactly is that pump located?
An opinion is like an asshole,everybody has got one.
saf
Post by saf » Thu Oct 12, 2006 2:59 pm
Looks like they might have even seized up.
Might need to get a different unit fitted.
They do only work when going a certain speed. Not sure what. Best to take the car for a run on the motorway or dual carriagway and and just before you get off, activate them. Get down from the car when off carriageway and check for water on lamps or body.
SimonS4MTM
Post by SimonS4MTM » Thu Oct 12, 2006 4:21 pm
Mine work when stationary
S4Al
Post by S4Al » Thu Oct 12, 2006 4:28 pm
Snap
david7m
Post by david7m » Thu Oct 12, 2006 4:35 pm
Double snap! You can see when moving that they have worked because they spray over the bonnet and screen, plus make a noise ;)
APR 270bhp S3, Mixer K6 750
whisky180
Post by whisky180 » Thu Oct 12, 2006 8:56 pm
u need the lights on and u need to keep the washer held on for longer than a quick spray on the windscreen. and they work if u are ststionary
noggy blue s4, mildly modded
h8cak
Post by h8cak » Thu Oct 12, 2006 11:11 pm
Right, I have tried the washers with the lights on and gave it a good long pull back (Oh sir) I herd a noise like a pump but the washers didnt pop up? I can manually pull them up an they dont feel sezied? Any ideas?
Wide Body S4
UKS4APR1
Post by UKS4APR1 » Thu Oct 12, 2006 11:51 pm
Take a look at this article, explains everything....... http://www.audiworld.com/tech/misc28.shtml
saf
Post by saf » Fri Oct 13, 2006 2:36 am
Somethings wrong with mine then. Ill shall have a quick check in the morning.
Mine only seem to pop up at speed.
Might be different for face lift midles and pre facelift. CAn you guys confirm whther you have a facelift or not. Mines a facelift. If you have facelifts then I defo have something up with mine.
jeffw
Post by jeffw » Fri Oct 13, 2006 6:23 am
mines a facelift and they work when not moving
h8cak
Post by h8cak » Fri Oct 13, 2006 9:04 am
Mines a pre facelift and nothing when standing still?
Wide Body S4
Users browsing this forum: No registered users and 261 guests
