32valve or 40valve
B6S4John
32valve or 40valve
Post by B6S4John » Sat Oct 07, 2006 12:16 pm
Why have Audi gone from 40 valve V8 in the S4 to 32 valve V8 in the RS4?????
Last one dead's a sissy.
DavidT
RE: 32valve or 40valve
Post by DavidT » Sat Oct 07, 2006 1:13 pm
The new 4 valve head flows better.
PetrolDave
Post by PetrolDave » Sun Oct 08, 2006 10:15 am
There's no room in the top of the cylinder to fit 5 valves, a spark plug and a high pressure (FSI-type) direct fuel injector - so they had to remove a valve.
ZeroK66
Post by ZeroK66 » Sun Oct 08, 2006 11:54 am
As Dave said :)
definatelymaybe
Re: RE: 32valve or 40valve
Post by definatelymaybe » Mon Oct 09, 2006 9:50 am
PetrolDave wrote:There's no room in the top of the cylinder to fit 5 valves, a spark plug and a high pressure (FSI-type) direct fuel injector - so they had to remove a valve.
Dave - do you work for Audi? :shock:
PetrolDave
RE: Re: RE: 32valve or 40valve
Post by PetrolDave » Mon Oct 09, 2006 1:27 pm
No, never have done. I did work for Lotus between 1988 and 1994 though.
In one of my surfing sessions I found a pdf that explains in quite a lot of detail the FSI system on the 1.4 Golf. It's not just direct fuel injection, but there's lots of other clever stuff - the water temperature is different when the engine is in FSI mode, the throttle is opened wide in FSI mode and the engine speed is controlled by the amount of fuel injected (just like in a diesel) - which means that a vacuum reservoir is needed to provide a vacuum for the brake servo and the flap that redirects intake air between 2 or 4 valves per cylinder, it also explains how the fuel injection strategy is different during a cold start and hence why the RS4 sounds MUCH noisier during the first minute or so after a cold start.
I don't know how to post a pdf file here, but I'm happy to email it anyone who PMs me.
B6S4John
Post by B6S4John » Mon Oct 09, 2006 7:58 pm
That makes sense, never thought of that. Thanks John
Mick_Jerry
Re: RE: Re: RE: 32valve or 40valve
Post by Mick_Jerry » Mon Oct 09, 2006 8:29 pm
Hello
I would be realy happy if you could send it to me, because i'm realy intersted in this techology(student of mechanical engineering).
Here is my email: mihajeraj(a)mail386.com I assume you will figure out the email adress.
Thank you very much.
ashleyadam
Post by ashleyadam » Mon Oct 09, 2006 9:29 pm
Excellent Dave
Users browsing this forum: Google [Bot] and 5730 guests
