notchy rs4 cab
dannymo
notchy rs4 cab
Post by dannymo » Tue Aug 22, 2006 8:06 am
got my rs4 black cab at the start of july.. awesome car.. the only annoying thing is a slightly notchy gear change esp when going from neutral to 1st.. was hoping it would loosen up.. but hasnt as yet.. guess ill have to take it back to audi.
simple1
RE: notchy rs4 cab
Post by simple1 » Tue Aug 22, 2006 9:00 am
My avant isn't too good, especially when cold. With 2000 miles on the clock, I would have liked it to have become smoother but it hasn't. Mine also bulks going into third both from second and fourth from time to time. Iii mentioned it to Audi when it was in getting fans fixed but no comment was made other than it is common to all RS models.
dannymo
RE: notchy rs4 cab
Post by dannymo » Tue Aug 22, 2006 9:04 am
well im only up to 700 miles in mine.. so maybe it will ease up.. 1st to 2nd and 2nd to 3rd not too bad.. but i need to really jam it into 1st from neutral.. the misses finds it really hard but to be honest not sure why i insured her on it in the 1st place! haha
dociain
RE: notchy rs4 cab
Post by dociain » Tue Aug 22, 2006 10:19 am
Have a problem from 1st to 2nd but only usually when cold. Has improved now car has done 3,000 miles and engine loosening up nicely!
PetrolDave
RE: notchy rs4 cab
Post by PetrolDave » Tue Aug 22, 2006 10:21 am
My RS4 Avant (1300 miles so far) has a much better gear change than either of my S4 Avants (2003 - 12000 miles and 2004 -31000 miles) ever had.
Daz
RE: notchy rs4 cab
Post by Daz » Tue Aug 22, 2006 10:53 am
I've had no problems with mine and I'm upto nearly 4000 miles now.
Cheers,
Daz :D
Audi RS4 Cabriolet with added Milltek - Gone :(
hershie
Post by hershie » Tue Aug 22, 2006 10:54 am
1st to 2nd seems to be my problem, if I’m not careful the gear change feels very juddery. Slightly higher revs during gear change seems to make it a bit smoother.
09 S4 B8 Deep Sea Blue
06 RS4 B7 Sprint Blue....SOLD
dxben
Post by dxben » Sat Aug 26, 2006 6:45 pm
N to 1st will losen up, it did for me. Also, there is a technique to it. If you try to slide the shifter all the way up the left hand bank of the box, you'll run over the notch. The trick is not to try to slide up against the wall of the gearbox, but put it just shy of the wall, to avoid the notch.
You'll get a smoother shift that way, but still won't be as smoth as the other gears.
Btw, my 3rd gear can be crunchy at times, a bit notchy. No grinding noise, just a tactile crunch.
I think the gearbox in the RS4 is very very good, but still probably shy of an S2000 or an M3 gearbox.
Users browsing this forum: No registered users and 158 guests
