First Time VAG-Com logs - any advice appreciated :)
TWH
Post by TWH » Mon Aug 14, 2006 6:35 pm
Hi guys, just got my vagcom through the post this morning - very quick delivery given it was only ordered late on wednesday :)
These are the only faults that have come up on an auto scan, so I was wondering if anyone could shed any light.
The alarm trigger I know about (me trying to find out what it sounded like to know what to listen for in future ;) )
The lambda sensors I realise may not be much but the charge pressure control sounds like it could be something worth worrying about.
4 Faults Found:
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 35: Centr. Locks
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15178
Shop #: WSC 63251
3 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00956 - Key 2
09-00 - Adaptation Limit Surpassed
2001 Avus Silver RS4, APRacing 6pots - Gone, but not forgotten :(
Nige_RS4
RE: First Time VAG-Com logs - any advice appreciated :)
Post by Nige_RS4 » Mon Aug 14, 2006 6:46 pm
G62 sensor needs replacing (common problem). Suspect DV's or MAF will give the charge pressure control error. What DV's are you using at the mo?
HTH
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
TWH
Post by TWH » Mon Aug 14, 2006 6:56 pm
Had new DVs and MAF a few months ago after a health test at MRC. Running standard DVs. Is the G62 sensor something that's easy to get to and replace?
Cheers for the input :)
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 65 guests
