Longer 6th gear ?
2.7 V6 30v biturbo - 380 bhp
dodgydave
Longer 6th gear ?
Post by dodgydave » Wed Aug 02, 2006 11:42 am
Tekkies,
I'm just overhauling my gearbox. (I had one of the old noisy 1st gear once!)
And because I'm going to run quite a bit of power with the new engine I thought it would be sensible to lengthen the 6th gear for those German Autobahn moments! ;-)
I just like to drop around 200-300 rpm. I’ve been aimlessly looking in ETKA but couldn't find a suitable gear.
Anyone know who does them or which AUDI gearbox I could get it from?
Help's like always appreciated.
S2tuner
Trader (Expired)
RE: Longer 6th gear ?
Post by S2tuner » Wed Aug 02, 2006 12:00 pm
Dave, the RS4 6th gear has a ratio of 0.684. You can go lower by using the following 6th gears from diesel 01E gearboxes:
01E 311 362 L, 0.6 ratio
01E 311 362 D, 0.56 ratio.
Prices, £229.38 incl VAT from your friendly Audi dealer. Ouch but not that bad. 0.6 Wouldn't be too bad IMHO, 0.56 would definitely be too low and the drop from 5th to 6th would be huge IMHO.
HTH,
Mihnea
PS: I'd never done this search before, it took me 5 mins to find them in ETKA...
dodgydave
Re: RE: Longer 6th gear ?
Post by dodgydave » Wed Aug 02, 2006 12:15 pm
S2tuner wrote:Dave, the RS4 6th gear has a ratio of 0.684. You can go lower by using the following 6th gears from diesel 01E gearboxes:
HTH,
Mihnea
Thanks ! It's easier if you know where to look. ;-)
Those numbers you stated don't show up on my ETKA. Maybe my version is incomplete/old??? Just out of interest, what engine/car are they from ?
Cheers,
S2tuner
Trader (Expired)
RE: Re: RE: Longer 6th gear ?
Post by S2tuner » Wed Aug 02, 2006 12:23 pm
Audi A4 2.5 TDI quattro I think, gearbox codes are: DQT/FTF for 362D and EHW/FTK for 362L. ;)
I just selected A4Q 2000 and worked my way from there ;)
Cheers,
Mihnea
Golich
Post by Golich » Wed Aug 02, 2006 10:07 pm
Dave who is doing your gearbox work?
I only know of one guy who advertises in Audi driver. Its always good to have a recomendation when needed!
DavidT
Re: RE: Re: RE: Longer 6th gear ?
Post by DavidT » Wed Aug 02, 2006 10:18 pm
Golich wrote:Dave who is doing your gearbox work?
Good question, I'm interested in that info too.
Also, how do you change just one gear in the cluster :? :oops:
Golich
RE: Re: RE: Re: RE: Longer 6th gear ?
Post by Golich » Wed Aug 02, 2006 10:37 pm
While I've never stripped a modern car gearbox (Plenty of bike gearboxes) and a few old car boxes, Aye late 1970 escorts etc in my experience each gear is loose on the shaft so you can replace an indivual cog if you want. It would make sence to me that this goes for most gearboxes as I can't imagine how they can cost effectively manufacture a complete set of cogs in one go. I could be wrong....
dodgydave
Post by dodgydave » Thu Aug 03, 2006 10:46 am
I'm doing it myself as I don't really trust many mechanics in the UK. Especially with gearboxes as they are quite specialized work. I've done quite a few VW and AUDI S2/RS2 6th speed before. Looking at the manuals this box doesn't seem that different.
Also, I called a few places to get some prices and the ‘lack’ of competence and horrendous prices for the work put me right off. I mean if you advertise that you have 20+ years expertise with AUDI & VW gearboxes and don’t even know what a S4 or RS4 is, isn’t really getting my vote of confidence!! ;-)
Cheers,
dummi
Post by dummi » Thu Aug 03, 2006 10:53 am
thanks for asking the question and getting those pn up , that will do nicely for cruising gear
rweir
Post by rweir » Thu Aug 03, 2006 11:28 am
Going on the following calculation
7250 (RPM) x 60 (miles per min) / 4.111 (final) / 0.684 (6th) / 806 (tyre rev per mile) = 191 MPH
So with the new 6th gear
7250 x 60 / 4.111 / 0.6 / 806 = 218 MPH
All we need from you Mihnea is the power to do it!
DavidT
Re: RE: Re: RE: Re: RE: Longer 6th gear ?
Post by DavidT » Thu Aug 03, 2006 10:36 pm
Golich wrote:While I've never stripped a modern car gearbox (Plenty of bike gearboxes) and a few old car boxes, Aye late 1970 escorts etc in my experience each gear is loose on the shaft so you can replace an indivual cog if you want. It would make sence to me that this goes for most gearboxes as I can't imagine how they can cost effectively manufacture a complete set of cogs in one go. I could be wrong....
I'm with you there Patrick, but was wondering how you can change the size of one gear without changing it's opposite number in the box. I'm often wrong though :)
S2tuner
Trader (Expired)
RE: Re: RE: Re: RE: Re: RE: Longer 6th gear ?
Post by S2tuner » Thu Aug 03, 2006 11:03 pm
What opposite number do you mean, David? The gears are pressed on the main and secondary shafts and the synchro hubs are the same for all these gearboxes that I've listed above.
Mihnea
viperbl
Post by viperbl » Mon Aug 06, 2007 11:22 am
Just to confirm then, All we need is the part number "01E 311 362 L", which is the actual 0.6 ratio, 6th gear. The current syncro's and 5th gear in the RS4 B5 box are quite happy to sit with this?
Cheers, rich
RS4 B5 Saloon8) with 750+ bhp :D
viperbl
Post by viperbl » Mon Aug 06, 2007 1:08 pm
Just spoke to Audi, 198 quid for the part, and they said I had to order to get a release date on the part. The part is on back order with the factory.
So, placed the order and they said they should give me a call tomorrow with a release date ... what a pain ...
Anyone know of a quicker way to get hold of this part? I imgaine not even a breakers could help with this, as they will not break a box for just 6th gear would they ????
dummi
Post by dummi » Mon Aug 06, 2007 1:19 pm
they'd be more likely to sell you the whole box, but maybe that is the quickest way
