S3 DTC's - help needed please!
DavidT
Post by DavidT » Tue Aug 01, 2006 11:31 pm
Can anyone shed any light on these codes please ? TIA
VAG-COM Version: Beta 606.5-UD
Saturday,01,July,2006,21:58:26
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Address 01: Engine
Part No: 8L0 906 018 K
Component: 1.8L R4/5VT 0003
Coding: 05610
Shop #: WSC 06435
1 Fault Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 35: Centr. Locks
Part No: 8L0 862 257 P
Component: CV-Pump, Alarm, RC D13
Coding: 13130
Shop #: WSC 00736
2 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
oliew
RE: S3 DTC
Post by oliew » Wed Aug 02, 2006 12:16 am
Not sure about the engine one one but the others, ive had the alarm DTC when i left my window down once and the alarm was triggered by something, the central locking pump might have a pipe leaking on one of the door locks or the boot lock? i think door panels off and boot trim to check tho, do the doorlocks always come up when you unlock?
hth
Ol
S4 B5 - MRC
flashyg
RE: S3 DTC
Post by flashyg » Wed Aug 02, 2006 9:42 am
alarm and cv pump ignore.
Secondary air system is the warm up system it has a leaky pipe I would think.
Shouldn't be to difficult to get it checked out.
G
DavidT
RE: S3 DTC
Post by DavidT » Wed Aug 02, 2006 10:20 pm
Thanks folks. I'll reset them and have a look at the intake system.
Morpheous
Post by Morpheous » Thu Aug 03, 2006 11:40 pm
Hi David, there is a valve for the secondary air on the side of the head. It has a large flat top with a tiny hole in the centre. When starting from cold wait for the air pump to start then put your finger over the hole, if the diaphragm is split, you will hear a change in noise as the valve now lifts from its seat introducing the air.
I am aware of a TT having most parts inc solenoid valve and hoses being replaced with the light still coming on sporadically. The fault was eventually traced to this combination valve. This is the easiest way to test it quickly. It is a sod to change on an ARY 180, not sure on a BAM 225.
If this fault flagged on an old V6 2.4/6/8 or V8 4.2, it always seems to be the vac hose split or cracked due to heat from the proximity of the exhaust manifolds. They go right where the hose joins the combi valve.
Interior monitoring simply shows the system was triggered from inside sensors. (you can turn off or use adaption ch 1 to reduce sensitivity). Or close windows.
Pump system has leak for other code. The pumps get very hot even with the cutout when leaks occur.
DavidT
Post by DavidT » Thu Sep 07, 2006 12:19 am
Morpheous wrote:Hi David, there is a valve for the secondary air on the side of the head. It has a large flat top with a tiny hole in the centre. When starting from cold wait for the air pump to start then put your finger over the hole, if the diaphragm is split, you will hear a change in noise as the valve now lifts from its seat introducing the air.
Thank you Simon.
David
Return to “DTC / VCDS”
