Anyone looked at Lemmiwinks. Looks like fine tuning can be made to the ECU. Will it work on a B5 S4 ecu?
http://forums.fourtitude.com/zerothread ... 056&page=1
I know it's dangerous to play but just interested
Lemmiwinks
RE: Lemmiwinks
Doesn't work on euro ECUs as far as I know. Never worked on mine anyway. You can
do pretty much the same thing with adapation channels anyway if you know a login
for your ECU. It's probably of limited value unless you don't have access to someone
(Mihnea) who can custom remap your ecu.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
RE: Lemmiwinks
I only want to be able to try and move my timing advance forward a little when I've gutted the pre-cats and maybe reduce boost a little...
Mark
I think 99/5 is the point that it would connect to ecu. I think it needs CAN bus or atleast CAN bus cars have an instrument cluster that lemmi can connect to.
I cut my instrument cluster power wire when I tried to make it work with my 99/2 but it didn't help. there was a second power wire but I did not want to fidle with it anymore.
