TV on the move
AndyS
TV on the move
Post by AndyS » Sun Jul 23, 2006 11:25 am
Hi
I know its been covered before and I looked back at other threads but any references to links and files are not working anymore.
Does anybody have detailed information on how to get TV on the move on Navplus in an RS6?
Andy
S4INT
RE: TV on the move
Post by S4INT » Sun Jul 23, 2006 7:57 pm
If its the same as the RS4 Nav+, then all you need to do is disconnect the GALA wire (white/blue on mine) from the rear of the head unit.
Apparently you may lose some accuracy on your GPS position, as the Nav unit uses the GALA signal in conjunction with the satellites to give a more accurate position, and also (not sure) but I think you also lose the speed dependant volume control.
I have run a very simple "loop" into the glovebox in my car so I can connect and disconnect whenever I want to. I know others have fited a discreet swith under the dashboard as an alternative.
Hope that helps,
Paul.
Golf R - with added MRC
Sprint blue B7 RS4 Avant - Sold
Ultimate Silver Nissan GT-R - Sold
Avus MRC 470 B5 RS4 Avant - Sold
AndyS
Post by AndyS » Sun Jul 23, 2006 9:53 pm
Paul
Thanks for that.
How do you get at the wires?
Andy
SteveH
Post by SteveH » Wed Jul 26, 2006 8:57 am
Andy, for RS6 I know that others (without electric blinds installed) have used this blank button space to put in a switch for tv in motion.
Present:...
Past:
S4INT
Post by S4INT » Wed Jul 26, 2006 11:23 am
Andy,
You need to remove the Nav unit - four keys required which you can buy from Halfords or just ask your dealer if he can pull it for you.
Cheers,
Paul.
Return to “Electrical”
Users browsing this forum: No registered users and 92 guests
