A repost of what I've put over on the S2 forum but if any of you can help me then it would be fantastic
I'm seriously confused, my car, an RS2 has an OEM single CD player badged 'Gamma'. It's pretty useless so I want to replace it with a Sony MP3 Cd player I already have with standard ISO connectors.
So I went out and bought a harness adapter for an Audi 80 from Halfrauds without removing the head unit first (shoot me now). On removing the 'Gamma' (a panasonic manufactured unit) I found the normal brown and black plugs. As well as this was a spade terminal for earth and a red plug (larger than the brown or black, lots of wires) with connections to the on board computer and some other stuff I don't understand.
Has anyone else seen this harness or have any idea where I could get a harness adapter for it?
I tried plugging in the Sony and not bothering with the red plug but it remained powered on all the time and only delivered sound to the front speakers. On examining the brown speaker plug on the car's harness it became obvious that this plug only has connections for the 2 front speakers. The rear's must be connected via the red plug.
Needless to say this is driving me insane.
OEM Single CD Gamma
Re: OEM Single CD Gamma
Hi
I got one of those to put on my rs2 (what to keed all original as possible) unfortunently it as a faulty CD.
I was looking for original harness cable from this CD gamma. info etc...
As far I know, the audio outputs are not amplified (this unit doesnt have amp) so I supose your speakers have amp somewhere.
the only thing I could help you is maybe a stikker pic that was in rear of the unit with simple schematic (realy simple - lack of info)
later at home will try to find that pic and sent it to you.
does your gama still have a working cd?
LHD wrote:A repost of what I've put over on the S2 forum but if any of you can help me then it would be fantastic
thanks RS2.pt, it's the speakers that are amplified and I finally got a lead to convert to standard ISO- you also need another lead to do the front speakers and ISO power connectors. I'll post the lead part number I have but it was supplied in Nederlands so may not be much use to others.rs2.pt wrote:Hi
Greetings to you in Lisboa, my mother lives in Algarve so I hope one day to drive down there via Lisboa, maybe I see you there!
Hi
If you come thru Lisbon, say something
So, this come a bit late, but this is the info on my radio:
If I had more infor about thos connections on pick it would help me, I could make a custom connections, because my RS2 didnt came with original ones, I was already modded with ISO.
In other words I think I am tryibg to make the oposit of you
Are you will keep your original GammaCD ?
