Groans from Power Steering - Advice Please
rjpatrick
Post by rjpatrick » Fri Jun 02, 2006 12:18 pm
Does anyone have any ideas about groaning power steering?
Symptom is that when turning on approx 1/2 lock to the right the steering groans, not all the time but often enough to have me worried.
Car is under warranty (just) 03 Standard RS6, 38k miles.
Now at Audi (Amersham) for the second time - first time couldn't decide whether to replace steering rack or pump and opted for pump as seemed quicker (and no doubt cheaper option) - didn't fix the problem though.
Thought I had read something about this before but can't find it now and Audi don't seem to know. Amesham currently talking to Audi central for advice.
Look forward to hearing from you all.
rjp
03 RS6 Black Outside + Black Inside
SteveH
RE: Groans from Power Steering - Advice Please
Post by SteveH » Fri Jun 02, 2006 12:23 pm
Present:...
Past:
DrB
Post by DrB » Fri Jun 02, 2006 12:34 pm
Mine groaned like that. Took it to Audi - they stated it just needed lubricated. It now no longer groans!
RS 6+
2001-2006 S4
2006-2012 RS6
2012-2016 ML350 CDI
2016-2018 RS6 PE
2018 - Tesla MS100D
mwcltd
Post by mwcltd » Fri Jun 02, 2006 12:35 pm
I have had this problem for about a year. The first time I reported it they found that the power steering fluid was at half level. The noise went away for a while and is now back again typically occuring when I am moving slowly and I turn to the right slowly.
I have reported this to the garage and the next step is the power steering pump as it is easier to replace than the rack.
RS6+ with MTM Stage 3
rjpatrick
Post by rjpatrick » Sun Jun 04, 2006 10:57 pm
mwcltd wrote:I have had this problem for about a year. The first time I reported it they found that the power steering fluid was at half level. The noise went away for a while and is now back again typically occuring when I am moving slowly and I turn to the right slowly.
These are exactly my symptoms - now I have a new pump so expect it won't help you either. Keep in touch - Amersham now talking to Audi Central (very....very ..... slowly) I'll be calling them tomorrow to see if they have made their minds up.
Still hoping they'll lend me something nicer - correction as nice (S8/New RS4) while they think about it.
Watch out for update.
rjp
SteveH
Post by SteveH » Mon Jun 05, 2006 7:39 am
rjpatrick wrote:Still hoping they'll lend me something nicer - correction as nice (S8/New RS4) while they think about it.
Don't rate your chances on that one, I even ended up with a Volvo at one stage whilst my suspension was on back order!
Present:...
Past:
rs666
Post by rs666 » Mon Jun 05, 2006 8:11 am
Off topic.....mwcltd can you check your private messages please I am trying to send you your RS6 keyfob :roll: look at linkee towards top right next to Profile link ta
fenny123
Post by fenny123 » Wed Jun 14, 2006 12:27 am
Had the same issue; steering pump was replaced; all fine now.
Told that the fluid was not circulating properly in it.
RS6 Saloon Ebony Black; Optic Kit.
rjpatrick
Progress on Groans
Post by rjpatrick » Thu Jun 22, 2006 11:16 pm
At last Audi have agreed that steering rack is covered by warranty - in on Monday (for the week) to have it changed - let's hope it makes a difference!
rjp
rjpatrick
RE: Progress on Groans
Post by rjpatrick » Thu Aug 03, 2006 1:31 am
[quote="rjpatrick"]At last Audi have agreed that steering rack is covered by warranty - in on Monday (for the week) to have it changed....
Well that was an interesting week, went in on 26th June, finally got complete car back on 2nd August.
Have new steering rack - groaning almost eliminated.
Have new driver's door - conflict between door and some part of Audi lifting gear (described as a scratch) - until new door didn't fit properly. Door top trim on back order. Interesting steering clunking also installed.
Finally all fixed yesterday, clunking is misaligned arm, trim fitted, overspray removed.
At least it was warranty!
Let's see how long it takes for the groaning to get going again.
rjp
03 RS6 Black+Black
SteveH
Re: RE: Progress on Groans
Post by SteveH » Thu Aug 03, 2006 7:57 am
rjpatrick wrote: Have new driver's door - conflict between door and some part of Audi lifting gear (described as a scratch)...
:shock: Thats one hell of a scratch to need a new door!
Present:...
Past:
fenny123
RE: Re: RE: Progress on Groans
Post by fenny123 » Sun Aug 06, 2006 11:52 am
Interesting... my pump was replaced to stock a groan (further up this thread) It now does the same again.... Surely I dont need a rack as well !!! ????
Has it fixed it ??????
installer69
Post by installer69 » Sun Aug 06, 2006 7:54 pm
Mine has done this for 34,000 miles, not all the time, and never when at the dealers or on a road test!!
My warranty is up in 5 months.
I think it is more likely to happen when pulling away at low speed from a junction. Strangely, mine only seems to happen going right. Also in a multistorey carpark going up it did it a couple of times.
Of course, Audi have never heard of it which brings me back to my suggestion for an owners' problem log.
Nachteil durch unerprobte Technologie
rjpatrick
Groaning steering
Post by rjpatrick » Sun Aug 06, 2006 9:54 pm
Hi Installer and Fenny
I had the pump replaced a while back - didn't fix the groan at all.
Installer - you describe the symptoms perfectly (pulling away, turning right, haven't tried a multistorey yet), this is what mine (with the new pump, rack and door :roll: ) now does.
Essentially I have given up as the rate of damage is higher than the rate of fixing.
Replacing the rack has improved the problem - it is still there but now at an undemonstrably low level. Annoying - probably the equivalent of a water hammer and just needs a clip at the correct position on a hose - if they knew what to do could probably save themselves thousands.
Let me know how you get on - if you get it fixed etc.
rjp
03 RS6 Black/Black (and that's just my mood - no really it still drives well :D )
marmite
RE: Groaning steering
Post by marmite » Sun Apr 01, 2007 8:48 am
Sorry to bring this up but mine has the same noise
I suspect it is the restrictor in the pas pipe that is faulty
Going in tom for it all to be sorted
DRC, BUckled wheels and groan from the steering, If they want to throw all major parts of the steering at the car I don't mind if warranty cover it
03 RS6 Saloon Daytona Grey | Milltek | RS6+ Wheels | RS6 Mats | Tesco Club Card Points
Users browsing this forum: No registered users and 301 guests
