K03-04 Hybrids?
K03-04 Hybrids?
Any1 ever though of going down this route.
That way you would keep the excellent low down grunt of the S4 but would get better top end like the RS4.
Not sure if it can be done or what sort of max power they would produce.
I remember driving Harry's MTM'd RS4 it had loads and loads of power but took a wee bit to get going, where as my MRC'd S4 was instant but had no where near as much top end power. If we could have both it would make for a very fast car.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
RE: K03-04 Hybrids?
It has been done, Paul, but the outcome wasn't very positive, too high back pressure from the wee K03 hot sides and not enough top end power could be achieved. This along with some reliability issues from what I've heard too...
IMHO not a great idea. straight K04s on an S4 aren't that laggy and low RPM grunt is better than an RS4 due to the different head port design on the S4.
HTH,
Mihnea
HTH,
Mihnea
RE: K03-04 Hybrids?
however, if you want a pair of K03s for experimental purposes your more then welcome to them. You still got them Minhea
my cars for sale
Cheers Mihnea that does help. So I will scrap that idea. Good to know the S4 will build boost a wee bit quicker than the RS4.
Thanks for your offer Andy but I have no idea what I would do with them apart from prob take them to bits just to play
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
It means you better watch out Harry
Not sure but prob the RS4 head will have bigger more free flowing ports to aid the amount of flow higher up the rev range, but the bigger the ports the slower the gasses will travel so will hurt spool up slightly. This is only a small prob low down the rev range.
I think Volume and Velocity both have a bearing on turbo spool time and it seems to be a bit of a compromise.
Smaller ports = fast flowing air but restrictive @ high revs
Larger ports = slower air but more of it for making bigger power.
Once the turbos spool up bigger ports all the way.
Well thats my understanding anyway
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
so does that mean having 2.4 cylinder heads gives you even better flow through the valves making more power or is it just beacuse they have bigger valves being from a N.A engine...
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
Ok maybe not
Good to know Dave.
Sorry Woody I have no idea re the 2.4 heads
Good to know Dave.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Take a look at the torque curve of a K04'd S4 and compare to a remapped K03 S4 and you'll see that the extra lag is almost negligible.
2001 Silver S4 Avant
duncanhancox
- 2nd Gear
unfortunately the torque curve doesnt really tell you anything about lag - only lack of boost at lower revs
the dyno run is done with the throttle wide open all the time and allows the revs to build up - real lag shows up when you press the throttle and it takes time for the torque/boost to arrive - this doesnt show at all on the torque curve, but a larger turbo will have less low down torque and probably more lag so the 2 are often associated together with larger turbos
duncanhancox
- 2nd Gear
How about an IHI turbo kit??
More power and torque with a good remap. Jabbasport are doing quite well with that set up. K04's are quite a small turbo to be dealing with a lot of exhaust gases.
Just a thought as I am having a 1.9 rebuild to my S3 but power/torque will be severely limited till I can afford to put the IHI kit on (like 100bhp). Also the IHI turbo tends to be quite reliable.
