HELP ON ALPINE FIT
HELP ON ALPINE FIT
I've got myself a ALPINE iva d900r unit , will i have any problems fitting it in my car as i've got bose system as standard . thanks for any help grizz
Unit 20
0151 3366888
0151 3366888
RE: HELP ON ALPINE FIT
Grizz depends how much of the RS4 bits you have in the car?
The RS4 Centre console is a complete wanker to fit an aftermarket standard size unit too. It is double din for staters and no one makes the adapter kits.
However, is you have the S4 dash then you should easily buy some adapters to make the actaul unit fit in.
Regarding the wiring I believe it is very complicated due to the Bose active system, however, I also believe there are adapters to make this work without chopping and cutting at things.
I searched all of this when I was doing my RS4 and then just gave it to the pro's to do. If my brain was working better, I would be able to remember the names of the companies - sadly alcohol abuse has turned it to mush...
Thanks , i'am useing the s4 dash so i know that's ok. The alpine unit has a brain unit that runns the system. looks like fun .
Unit 20
0151 3366888
0151 3366888
BRETTCOLLINS
- 5th Gear
have problems with I fitted my alpine system to my car. ended up ripping out the old wiring and all the interior and starting again. takes longer but works better and is much cleaner install. one amp, alpine headunit, focal speakers and sub.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
