B6 S4 brakes on a B5 S4
MarkB
Post by MarkB » Wed Apr 19, 2006 3:54 pm
As the title says... Anyone know if they would fit??
Mark
tartan_rob
RE: B6 S4 brakes on a B5 S4
Post by tartan_rob » Fri Apr 21, 2006 5:06 pm
would that give much better braking over std?
If you are buying new, forget the B6 brakes and jump straight into the RS6 ones.
2017 Kawasaki Z1000
2014 RS6
2014 S1
MarkB
Post by MarkB » Fri Apr 21, 2006 5:36 pm
I wouldn't buy all new and I'm back thinking maybe just fit B5 RS4. People seem to think the standard B6 S4 brakes are good so it just got me thinking...
I'll see what come up first, not many people seem to be changing their brakes on the B6's yet.
Mark
CliveH
Post by CliveH » Fri Apr 21, 2006 9:04 pm
The comments on the S4 B6/B7 forum suggest that these brakes are much better, but I'm not sure if they'll fit the B5 without a modified caliper mounting bracket.
Clive
MarkB
Post by MarkB » Fri Apr 21, 2006 9:09 pm
But it does seem the B5 RS4 and B7 RS4 brakes bolt straight on to the B5 S4. I see somethings common there. I could always be completely wrong though
I'm not planning much power or any track use so don't really want the expense of large multi piston claipers and curved vain discs...
Mark
CliveH
Post by CliveH » Fri Apr 21, 2006 9:22 pm
The B7 RS4 brakes do bolt straight onto the B5 S4, providing you have 18" wheels with ET35 or ET45 plus 10mm spacers. I think the RS4 B5 ones will bolt straight on, but I'm not 100% on this.
If you're looking for a cheaper solution, you can pick up 2nd hand Porsche 6 pots for sensible money (about £300) plus suitable discs and pads for about the same again.
Clive
MarkB
Post by MarkB » Fri Apr 21, 2006 9:25 pm
RS4 B5 require 18" wheels... £600 is more than hope to spend. Tight budget for me unfortunatly :(
Mark
GrimReaper
Post by GrimReaper » Sat Apr 22, 2006 5:55 pm
What sort of price are used RS4 (B5/7)calipers going for these days. Wanna get a set for mine eventually but got the remap and cambelt change all at once so need to know how many pennies to save. Also I see Porsche calipers got a mention does anyone know what model to get them from and whats the fitting like as i take it they wont just bolt straight on.
Cheers. Steve
CliveH
Post by CliveH » Sun Apr 23, 2006 12:47 am
You can probably pick up used B5 RS4 calipers for as little as £150.
As for B7 RS4, they're unlikely to be any for a while, but they're identical to the RS6 ones, and you can find those on ebay for around £400.
You can use the Porsche 993, 996, or Cayenne and possibly others. I think they all need a suitable mounting bracket though.
Clive
s4woody
Post by s4woody » Sun Apr 23, 2006 10:40 am
porsche cayenne bolt straight on..you have to use a high tensile bolt with a lock nut..the only way to fit them is to remove the pads and use the space for ya spanners..let me know if ya need a pic..
GARTH ROAD MOT CENTRE LTD
020 83353032
MarkB
Post by MarkB » Sun Apr 23, 2006 11:40 am
s4woody wrote:porsche cayenne bolt straight on..you have to use a high tensile bolt with a lock nut..the only way to fit them is to remove the pads and use the space for ya spanners..let me know if ya need a pic..
What disc is needed to use these? Will the standard RS4 work? Pics would be useful.
Mark
S4 OXON
Post by S4 OXON » Sun May 21, 2006 10:08 pm
So you will need 18"inch wheels for bettter brakes i take it then !
Or are there any better brakes than B5 S4 std set up ,That keep the same wheels ? That dont cost arm and leg :lol:
KayGee
Post by KayGee » Fri May 26, 2006 1:08 am
In a word no.
Porsche turbo (stoptech kit being best known) brakes fi tunder stock rims. However the RS4 B7 setup is similar price but does require 18" wheels.
Porsche Cayenne kit is ECS tuning stage 4.
Both are approx. same price $1900 + import +VAT + shipping etc...
Nige_RS4
Post by Nige_RS4 » Fri May 26, 2006 9:41 am
You can get the ECS stuff from the UK importer (at realistic prices too) ... www.jbrperformance.co.uk
The stage IV stuff is around £1275+VAT and is a complete kit incl. fluid & s/steel lines.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
