FATS help please...
rolskii
FATS help please...
Post by rolskii » Mon Apr 17, 2006 10:21 pm
Can someone clue me up to FATS please...
Want to try and get some logs before I do my downpipes this week.
1) So do I make some data channel logs on vag-com...?
2) What channels, exact rpm(4,200-6,500rpm in 3rd isnt it)..?
Also where are the post's so I can compare too, I have scoured loads and came up with an external web link to a tuners table that was generic...?
Thank you .... :D
David
DavidT
RE: FATS help please...
Post by DavidT » Mon Apr 17, 2006 10:34 pm
rolskii
Post by rolskii » Mon Apr 17, 2006 10:57 pm
Cheers David ... :thumb:
saf
Post by saf » Mon Apr 17, 2006 11:09 pm
Could someone explain step by step please how to obtain FATS on vagcom. I havent a clue either.
I have VAGCOM and compatible cable (USB)
Ive PM a few people too, if I get reply first Ill post on here. Thanks all.
rolskii
Post by rolskii » Mon Apr 17, 2006 11:15 pm
Saf,
The link above explains it pretty much, what are you unsure about exactly ...?
Have you unlocked your copy of vag-com or do you have a cable with a dongle in it, this will release the capabilities of the program../
David
maxxximus
Post by maxxximus » Mon Apr 17, 2006 11:27 pm
For FATS you really only need to log Block 3 (which is available on shareware version).
Ross tech explains the logging process http://www.ross-tech.com/vag-com/tour/m-blocks.html
Once youve logged a run you can then look at the data file using Excel or other spreadsheet application.
KayGee
Post by KayGee » Tue Apr 18, 2006 2:25 am
Or just put in the nearest figures to one of the many FATS calculators available...
http://www.weaselworks.net/cgi-bin/fats.cgi
Return to “DTC / VCDS”
