710A DVs standard fit on RS4??
I'm being careful not to "hijack" other threads - inspected a car for a forum member yesterday, http://www.rs246.com/index.php?name=PNp ... ic&t=53265 , and discovered it had 710A DVs fitted - were the 710Ns not fitted as standard to the RS4s...?
Clive
RE: 710A DVs standard fit on RS4??
ASAIK 2.7 s4/rs4 fitted with the A's but N's fitted to 1.8T TT from factory.
Simple and cheap upgrade to give you peace of mind.
Yep, only the TT had them.
And the 225 S3...?
Clive
When did the 'N' revision come out?kiwi_mtm wrote:My rs4 has 710A's, and this has always puzzled me why Audi didn't use the "N".
B7 S4 Cab
B5 RS4: MRC custom remap, Milltek 100cpi cats and rear system, RS6 8-pots, H&R PCS coilovers, H&R ARBs, AWE DTS, Tanoga Shortshift, Dynaudio / Focal / Genesis / iPod audio: SOLD, and still missed. One day....
710A was std fit on the RS4, the 710N version (rather than revision) came out for the 225BHP 1.8T engine and although the diaphragm is not as thick as the 710A, it is actually less prone to tearing.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Just swapped out two 710A's off 2001 B5 RS4 for two new 710N's. Neither 710A would hold vacuum from the nipple - pulled both apart for some fun and each had about 10-15m split in rubber diaphragm
2003 Daytona Grey RS6 Avant
2007 Daytona Grey B7 RS4 Cabrio on order
About as west as you can go in the colony without getting your feet wet.
Especially in imperial measurements !LSWP wrote:each had about 10-15m split in rubber diaphragm
now thats a big split!!
mm's of course !
PS My 2000 S4 had 710C's before being replaced with N's
Never heard of 710Cs - anyone know which car these are from??
Clive
It seems the 710C was used on some S4's in lieu of the 710A. To my layman eyes the A and C DV's look very similar (I now have duds of both in the store room somewhere). Audiworld has some commentary on it including the following (no responsibility accepted if all this is wrong!)
"... the TT uses a 710N valve which has a stiffer spring with a rubber diaphram. the 710C has the same spring with 3.5mm of travel up and down and a brass piston dome.
the 710N has a 7mm of travel with a rubber piston. ... "
Users browsing this forum: No registered users and 60 guests
