Mtm chip - how to verify if you have one?
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
Vances3
Post by Vances3 » Tue Apr 11, 2006 8:00 am
Hi guys I'm a new member from Auckland New Zealand and I need some help. I have a noggy blue 2001 S3. I was told by the dealer that I brought it off that it had an mtm chip and 250hp which I have begun to doubt big time.
Using a car performance computer I timed a 0-60 run the other night and it was just over the 7 second mark which is a lot slower than what mtm claim.
Is there any way that you can check whether the car has been chipped or not via diagnostic tests? I have spoken to the dealer (jag dealer) and asked for documentation about the chip and he simply told me that the last owner told him it was chipped and it felt like it had 250hp which is a poor cop out.
I'm going to get the car dynoed. What would you expect for a standard 210hp s3 at the wheels as opposed to a 250hp standard exhaust mtm s3?
I've searched the forums and I don't have a vagcom.
Thanks in advance
Vance :)
david7m
RE: Mtm chip - how to verify if you have one?
Post by david7m » Tue Apr 11, 2006 9:25 am
Hi mate :)
I suppose the best test would be to go out in another that is claimed to be standard, but that may be hard over there!
As for your 0-60 sprint, I think 7 seconds is slower than a standard car (think they are 6.7). Unless you are used to driving/testing cars, I doubt anyone can recreate the figures they quote!
If you did have Vagcom, it would show that the standard boost and torque limits had been exceeded...
APR 270bhp S3, Mixer K6 750
david7m
Post by david7m » Tue Apr 11, 2006 9:28 am
According to the 'sticky' thread at the top of the S3 forum, standard 0-100kph (0-62mph) is 6.6 seconds.
http://www.rs246.com/index.php?name=PNp ... ic&t=15235
Vances3
Post by Vances3 » Tue Apr 11, 2006 10:33 am
Thanks. i don't think it was a particularly good run especially 2nd to 3rd gear change. Mine is the 210hp model which i thought was a bit slower than 6.6. Have got in contact with some one over here with a vagcom who has offered to help and failing that we wil pull the ecu out. I have been informed also that there should be a mtm sticker on the ecu etc.
Ryan_s3
Post by Ryan_s3 » Tue Apr 11, 2006 3:19 pm
Boost pressure would be up on standard 0.9bar.
Image360bhp 342lb/t
Vances3
Post by Vances3 » Wed Apr 12, 2006 7:41 am
Thanks guys. I realised with some embarrasssment that I had run a 0-60 test on an incline and have had confirmation by a different audi dealer over here that the car has an mtm chip.
I had a quick diagnostic check done today and the car has a sporadic fault. The code is 17704 P1296 035.
Any ideas what the fault might be. Is it the maf?
david7m
Post by david7m » Wed Apr 12, 2006 12:54 pm
I think there is a section for VAG codes on the forum....
Paul-RS
Post by Paul-RS » Wed Apr 12, 2006 8:58 pm
17704
P1296
Cooling system malfunction
not one of the most informative fault codes available. :?
Vances3
Post by Vances3 » Tue Apr 18, 2006 5:42 am
Thanks PaulS3. Its getting serviced in a couple of months so will hopefully get it sorted then.
