Major Worry... Issue HELP.
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
s300tna
Post by s300tna » Wed Apr 05, 2006 5:11 pm
ok the sort version. (Audi S3 225 chipped by Superchips)
2 months ago car started mis firing under boast, about half way though rather than towards end of.
replaced all 4 spark plugs (fixed)
last week same problem but this time with ecu light on.
4 new coil packs- not fixed- 4 new plugs "again"- not fixed- cleaned maff- not fixed...
ecu light was fault on 4 (which is why i replaced coil packs)
the car can be driven at a normal pace right up to 120mph but as soon as you ask for that bit more its simply splutters.... will pull ok till about 3k then starts however if you go though that up to 4k will still pull but again if heavy on pedal mis fires.....
sorry final bit im sure its only mis firring on one piston. :evil:
grizz
RE: Major Worry... Issue HELP.
Post by grizz » Wed Apr 05, 2006 9:14 pm
Try unpluging your maf , if it's better you need to change it . grizz
Unit 20
0151 3366888
Ryan_s3
Post by Ryan_s3 » Thu Apr 06, 2006 6:32 am
plugs,coilpacks,maf and n75 are all prone to failure. What does vag-com say?
Image360bhp 342lb/t
s300tna
Post by s300tna » Thu Apr 06, 2006 3:32 pm
keeps making out its a coil pack problem of 4 but they have been changed!
s300tna
Post by s300tna » Thu Apr 06, 2006 3:33 pm
SLC Detailing
Post by SLC Detailing » Thu Apr 06, 2006 4:45 pm
Just on the off chance did u clear the codes after doing everything?
SLC Detailing
Post by SLC Detailing » Thu Apr 06, 2006 4:48 pm
S3Steve
Post by S3Steve » Thu Apr 06, 2006 7:41 pm
Does sound like the same symptoms i had when i lost a coilpack, is it possible one of the new coilpacks is faulty. Why not switch coilpacks around clear the fault codes then take the car for a drive and see if the fault transfers to a different cylinder.
2002 S3 | Jabba Remap | 277.7 bhp and 416.6nm | Bailey DV | H&R Springs | 8.5x18" BBS CH's fitted with 225/40/18 Yokohama Parada Spec 2 Tyres
s300tna
Post by s300tna » Thu Apr 06, 2006 9:42 pm
YES THANK YOU LORD....
finally fixed it was one of the new coil packs..
thanks guys for all your help, i can now go back to having fun with 270bhp......
mind you ryan 360bhp sounds so much more fun!
AGAIN THANK YOU.
Users browsing this forum: No registered users and 100 guests
