Rear Wash Wiper water not working
david7m
Post by david7m » Fri Jan 06, 2006 2:08 pm
Hi
Sorry if this has been covered before, I tried a search on the forum, but nothing came up with "rear wash wipe" !
On my S3, the rear wash wiper works, but when I try to spray the screen wash......nothing/little water comes out! It sometimes has a low pressure drizzle of water, but mainly nothing happens!!!!
The blade obviously keeps squeaking across the screen destroying the blade on the dry surface.
I can hear the pump when I try to spray water. The front one works fine. And there is plenty of screen wash in the bottle.
Any ideas?
Cheers.
david7m
RE: Rear Wash Wiper water not working
Post by david7m » Sun Jan 08, 2006 11:24 pm
The girlfriends Mark V Golf is also the same :(
APR 270bhp S3, Mixer K6 750
rallymanuk
Post by rallymanuk » Sat Jan 21, 2006 4:01 pm
is the washer jet blocked,
bakerdcb
Post by bakerdcb » Sat Jan 21, 2006 4:09 pm
Really quite a common problem on the S3 I think. Mine did this at least twice. Hose comes detached in a number of places. You just have to find out where. This may help :D
http://www.rs246.com/index.php?name=PNp ... ic&t=51416
david7m
Post by david7m » Sun Jan 22, 2006 9:45 pm
Thanks.
Its leaking in the engine bay, behind the air filter box/ABS bits :(
Can't seem to get to it though ......... need some tools ......
bakerdcb
Post by bakerdcb » Sun Jan 22, 2006 9:50 pm
Yep, I've had that one. Tricky bugger, best of luck :bigblink:
david7m
Post by david7m » Mon Jan 23, 2006 11:02 am
I've recently moved from the Midlands to Milton Keynes and all my tools are still up there :( Only have a chocolate spanner from IKEA and a set of cheap screwdrivers :)
Bakerdcb, what do I need to remove please?
Cheers.
david7m
Post by david7m » Sat Feb 11, 2006 9:44 pm
Now sorted - thanks :)
Had to remove battery cover, air filter box and a cover that protects the cables under the filter box. The join that had came apart was in there!
Pushed back together - job done :)
Return to “Electrical”
