Replacing Brake Fluid ?
DaveP
Post by DaveP » Fri Oct 21, 2005 4:52 pm
Hey all,
I need to flush the entire fluid and put some nice Castrol SRF in..
Is it just a case of bleeding it as normal but for an extended time to ensure that all the old fluid is out of the system ?
:roll:
DaveP...
Audi Allroad - Daily slogger
S1 Exige - Track beast
sitas3
RE: Replacing Brake Fluid ?
Post by sitas3 » Mon Oct 24, 2005 1:16 pm
basically yes Dave but try and syphon etc the old fluid out of the fluid reservior before (but not too much where you end up getting air into the system!)
you're supposed to flush the clutch circuit as well but I never did that!
DaveP
Post by DaveP » Tue Oct 25, 2005 12:27 pm
Thanks bud...I actually did it over the weekend...just bled the fluid through until mostly gone from the reservoir, then filled up with the new good stuff...
Was a piece of pee to be honest!
One man brake bleeding kit from Halfords @ 4.99 :thumbs:
DaveP...
sitas3
Post by sitas3 » Wed Oct 26, 2005 1:42 pm
I used a similar device, only I used too much pressure and nearly blew the reservoir apart! :oops:
Nige_RS4
Post by Nige_RS4 » Wed Oct 26, 2005 1:56 pm
Did you activate the ABS pump with VAG-COM (or keep the engine running) when you flushed the old fluid out?
DaveP
Post by DaveP » Wed Oct 26, 2005 2:24 pm
Nope...did wonder about this...but the Haynes manual I have didn't make any mention of it...
DaveP...
Nige_RS4
Post by Nige_RS4 » Wed Oct 26, 2005 2:40 pm
Yeah, there seems to be conflicting information about whether this is neccessary.
DaveP
Post by DaveP » Wed Oct 26, 2005 2:44 pm
The manual does mention something about the ABS if you have air trapped...taking it to a dealer etc...but mine was a straight flush through so I think everything is okeydokey...
DaveP...
