Help!
2.7 V6 30v biturbo - 380 bhp
Kenhk
Help!
Post by Kenhk » Sat Aug 06, 2005 6:10 pm
My car was running smoothly early today.
After parked for three hours, I could not turn it on again.
Actually, it is on but down within a second. :cry:
I tried unplug the battary and reconnect it after twenty mins.
It still down again after trun on.
Anyone has any idea?
ECU problem?
I was remap with Revo.
Pls help.
Ken
PhilT
RS246.com
RE: Help!
Post by PhilT » Sat Aug 06, 2005 7:09 pm
Sounds like the imobiliser... Have you tried the spare keys?
Kenhk
Post by Kenhk » Mon Aug 08, 2005 3:56 pm
Thanks Phil,
I have run Vagcom and found serveral fault code,
Address 01:Engine
18058 Powertrain Data Bus: Missing Message from Instruments Cluster
P1650-35-00
17978 Engine Start Blocked by Immobilizer
P1570-35-00
Readiness 0110 1100
Address 03: ABS Brakes
18258 Powertrain Data Bus : Missing Message from ECU
P1850-35-10---Intermittent
Address 17: Instruments
01177 Engine Control Unit
49-00-No Communications
Address 25: Immobilizer
No Faults Found
or DTCs not Supported by controller
or a Communication error occurred
What are all these about?
And anyone know where is the immobilizer located? built inside the ECU ?
I have checked with Revo because there is a function of anti-thief in their software. But Doug Harris replied it was not possible the software went into anti-thief without the SPS.
Is it true? Anyone has any experience with Revo as the same symptom?
The official dealer here has no idea at all! :bash:
My tunner claimed it might be a chip problem inside the ECU.
Is there any firm can fix the problem without replacing the whole ECU?
Thanks for any advice. :bowdown:
Ken
philipwalker
Post by philipwalker » Mon Aug 08, 2005 5:42 pm
If the codes are cleared does the car restart or the codes return?
Do you have both the keys in the car or even on the same key ring??
On occasions the reader coil on the key barrel picks up both keys and immobilises the car.
The "two key" one is not as daft as it sounds!!
http://www.pwmotorsport.com
PW Motorsport
01437 563929
Kenhk
Post by Kenhk » Mon Aug 08, 2005 8:23 pm
Thanks Philip
Yes, the code return after I cleaned it and restart the car.
It acts the same way, it starts then down within a second.
I also tried both keys with the same result but they are not on the same ring. :cry:
Any advice if any Audi guy or tuner here?
Ken
PhilT
RS246.com
Post by PhilT » Mon Aug 08, 2005 9:04 pm
Might be worth checking the connection to the ecu... Unplug and reconnect.
Kenhk
Post by Kenhk » Mon Aug 15, 2005 10:07 am
Phil,
I tried, nothing changed.
In any case, if I need to change or refresh the ECU, can I get free remap from Revo? as it is the same ECU and or same car,same user.
Does anyone have the same experience for remap?
Ken
RevoKev
Post by RevoKev » Tue Aug 16, 2005 9:30 am
Hi Ken,
have you had your Audi dealer look at the car? It's definatley a 'car' rather than software issue, have you had the clocks out or had any work done on anything prior to this happening? Your ECU, clocks, and key need to be communicating in order for the car to start.. something is obviously causing problems. It looks as though you're having ECU communication problems, could be down to wiring.
If you have to have your ECU replaced then we would put software on your new one. We have recently changed alot of our dealers in the Asian region. I'm not sure who you dealt with originally when you had software installed?!
Golich
Post by Golich » Thu Aug 18, 2005 1:29 am
Not that I think this will help you much the imobiliser is built into the instrument cluster. Or at least it was on my 97 S4.
Kenhk
Post by Kenhk » Fri Aug 19, 2005 4:56 am
Thanks Golich & Kev,
I will toll my car to Audi HK for inspection.
The software was installed through Gilbert of Invo
Will keep you post.
Ken
