RS4 Sway (antiroll) Bars Opinions?
2.7 V6 30v biturbo - 380 bhp
don
Post by don » Thu Jun 30, 2005 4:12 am
I have been doing quite a bit of sway bar research, here are the options:
________________________________________________________
Standard RS4 Bars: 30/15 mm front/rear.
Eibach: 30 mm front, rear?
Quattro Gmbh: 17 mm rear only
Whiteline rear bar: 18 mm
Neuspeed: 29/19 mm front/rear
H-Sport: 35/22 mm front/rear (adj) (both hollow)
H&R: 32/17 mm front/rear (both 2 way adj)
H&R: 32/21 mm front/rear (both 2 way adj)
_______________________________________________________________
I'm most interested in the H&R: 32/21 combo and if anyone here has tried it?
I have been told it is better for low speed cornering and turn in, which is fine given we have a max speed limit here of only 70 mph. :?
I've been quoted: £350 (530 Euro) with 10% club discount for the H&R + labour.
What does everyone think?
If anyone is interested in a group purchase please let me know?
Or if anyone knows of any good mail order suppliers?
thanks
Don.
Nordschleife
RE: RS4 Sway (antiroll) Bars Opinions?
Post by Nordschleife » Thu Jun 30, 2005 7:38 am
why are you more interested in the H&R 32/21 combo than the 32/21 combo? its not your todger we are talking about here, more isn't always better.
R+C
PhilT
RS246.com
Post by PhilT » Thu Jun 30, 2005 8:17 am
I have just ordered the H&R 32/21 combo, and have a large todger. The H&R kit cost about £220 inc VAT, not sure on the cost of fitting as it will be fitted with a number of other refreshed parts.
don
Re: RE: RS4 Sway (antiroll) Bars Opinions?
Post by don » Thu Jun 30, 2005 8:35 am
:lol:
Well.. glad someone else is going the big 32/21 combo and has a large todger.
Phil, £220 seems cheap and I'd get it VAT free as an export. Who are you sourcing this from? Do they have a website?
PhilT
RS246.com
RE: Re: RE: RS4 Sway (antiroll) Bars Opinions?
Post by PhilT » Thu Jun 30, 2005 8:45 am
I'll find the original source either tomorrow or Saturday.
Prawn
Post by Prawn » Thu Jun 30, 2005 9:07 am
32/21 on mine, put simply it works :thumbs:
Prawn
Jani
Post by Jani » Thu Jun 30, 2005 11:56 pm
ARB stiffness goes up in the 4th power of the diameter. This means that 17mm is 65% stiffer than a 15mm. 32/21 would give you 29% stiffer front, and 284% stiffer rear, so you would expect it to be more tail-happy.
GmbH bar does that too, but doesn't damage the ride too much.
don
Post by don » Fri Jul 01, 2005 10:57 am
I believe it is a spring/shock upgrade that reduces ride quality more so than a thicker sway bar.
I have been talking to Dietmar at H&R and he says,
"...With our 32mm front and 17mm rear bars the car goes a little bit in the direction understeer..."
"But we have developed a new 21mm rear swaybar for the RS4. With this bar the car handling goes more in the direction oversteer. With this bar you will achieve a decreased body roll and a perfect handling."
:D
DavidT
Post by DavidT » Fri Jul 01, 2005 12:00 pm
The H&R 32/21 sounds very good to me.
prawn, what did this upgrade do to ride comfort? particularly bump absorption independently side to side, does it make the car bounce because the roll bar stiffness pushes the other wheel up front and rear or have you not noticed much difference?
I assume it fits the B5 S4. Can anyone confirm please ?
I'm potentially interested in a group buy.
don
Post by don » Fri Jul 01, 2005 12:08 pm
We've had this discussion recently:
http://www.rs246.com/index.php?name=PNp ... ic&t=49624
Seems like RS4 bars will fit an S4, ask mikeyquattro.
DaveP
Post by DaveP » Fri Jul 01, 2005 12:17 pm
I think I've probably got the 17mm bar on the rear of mine...Might get chance to measure it over the weekend...
Going from the 'softer' setting on my rear bar to the 'stiffer' setting made a huge difference to the handling, I'd say a 21mm bar would be better still!
DaveP...
Audi Allroad - Daily slogger
S1 Exige - Track beast
dhali
RS4 Sway Bars
Post by dhali » Fri Jul 01, 2005 12:24 pm
Hi,
i have had the 32/21 H+R Combo on mine for about 5 months now (use to have standard set up) and i can honestly say it transforms the cars handling. I fitted them myself and set them FIRM at the REAR and SOFT at the FRONT.
They are very easy to fit, all you have to watch out for is the links on the rear( the nuts on them are prone to seize!!)
Prawn
Post by Prawn » Fri Jul 01, 2005 12:27 pm
Not much difference (until I put the 750lb/in springs on :shock: ) on ride comfort with just the ARB upgrade. Will be stiffer when one wheel goes down a hole/rut as it is loading the ARB.
No bounce though.
You do need to get the settings right on the adjustment though to get the real benefit, I have posted all my setting up before if you search through my posts.
Prawn
JonnyX
Post by JonnyX » Fri Jul 01, 2005 1:03 pm
Hi Phil,
If you could post where you got 33372-2 (32/21) then that would be great.
You can get them from an ebay.de shop for £240 but the guy wants 50E for
postage which seems too much to me.
Cheers,
Jon
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
johneroberts
Post by johneroberts » Fri Jul 01, 2005 1:53 pm
I had the H&R fitted and it did me proud until the last trackday i did in it at Silverstone, it managed to brake off in the afternoon, somthing i didnt realise until i took it off to sell.
It was quite a crack when it happened though
jr
Driving is believing
RS246 Founder
Users browsing this forum: No registered users and 93 guests
