Boost Pressure
2.7 V6 30v biturbo - 380 bhp
zeke
Boost Pressure
Post by zeke » Fri May 27, 2005 11:34 pm
I recently install a boost gauge (Auto Meter with memory and warning light) in my car, right now I´m running with the stock chip (I took the GIAC out because of the low Mileage) and my car is boosting only 17.2 psi, I don´t know what the pressure is in Bars, but is this right?
Adios y Gracias
:kissmyrings:
Zeke
PhilT
RS246.com
RE: Boost Pressure
Post by PhilT » Sat May 28, 2005 10:54 am
From here http://www.turbobricks.com/resources.ph ... nt=psi2bar
1 psi = 0.06895 bar
1 bar = 14.50326 psi
So 17.2 psi = 1.18594 bar
IIRC the stock code usually peaks at about 1.1 bar and holds at 0.8 bar.
zeke
Post by zeke » Mon May 30, 2005 4:06 pm
Gracias, Mercy, thanks
:biggrin3:
slippery
Post by slippery » Wed Oct 05, 2005 7:32 pm
Hi
I would like to know what the boost pressure (bar)
should be for RS4 with MTM 458 conversion.
Any help appreciated
Cheers Tom.
Golich
Post by Golich » Fri Oct 07, 2005 12:19 am
Is that the same pressure as the S4?
slippery
Post by slippery » Fri Oct 07, 2005 3:28 pm
Hi Golich
I don't know.
Cheers Tom
jsahlman
Post by jsahlman » Fri Oct 07, 2005 11:32 pm
S4 standard pressure is 0.8 bar. With chip app 1.5 bar
RS4 with MTM458 about 1.5-1.7 bar
PhilT
RS246.com
Post by PhilT » Sat Oct 08, 2005 12:06 am
Stock RS4 1.1 bar
MTM chip is variable, and has been seen as high as 1.8 bar.
slippery
Post by slippery » Sat Oct 08, 2005 12:45 am
Hi
Thanks for the quick reply
Cheers Tom.
Dippy
Post by Dippy » Mon Oct 10, 2005 1:15 pm
jsahlman wrote:S4 standard pressure is 0.8 bar. With chip app 1.5 bar
Not with K03s it isn't. About 1.3 bar is about as far as you can sensibly go without risking turbo damage, and even then 1.3 bar isn't healthy.
I know there is at least one tuner in the US who does a 1.5 bar S4 remap, but there are a lot of reports of turbo failure!
2001 Silver S4 Avant
jsahlman
Post by jsahlman » Mon Oct 10, 2005 3:54 pm
With KO3`s max boost was 1.5 bar with ABT chip. I know because I had one. In US S4 has smaller oil return lines than EU model. That`s why they have broke so many turbos. That`s what I have heard.
dodgydave
Post by dodgydave » Wed Oct 19, 2005 10:26 pm
I drive 1.7-1.8 peak with bigger chargers.
Never enough...
zeke
Post by zeke » Tue Nov 08, 2005 2:12 am
I recently install the MTM chip with the exchaust system and my peak is 26 psi or 1.8 bar. I did it, at sea level with a temp of 35 C (95 F) very hot with high humidity. When I run the car in Mexico City (2,250 mts or 7,382 ft. above sea level) my peak boost goes down to 20 psi or 1.38 bar.
My fuel economy at the highway at 160-190 kms is 15 L /100 km
Regards
DavidT
Post by DavidT » Tue Nov 08, 2005 10:08 am
Revo peaks at 1.4 bar. Seen it with my own two eyes :o :shock:
zeke
Post by zeke » Fri Nov 11, 2005 5:13 pm
Do anybody knows why when I go up in altitude (2,250 mts above sea level) my boost goes down to 1.38 bar from the 1.8 I'm getting at sea level
