Tyre Wear
Dalton
Tyre Wear
Post by Dalton » Tue May 03, 2005 3:20 pm
Just had the tread checked on my tyres. There seems to be uneven wear on both of the fronts i.e.
NSF 1.6/4/4
OSF 2/4/4
Has anyone else had a similar experience? Any ideas why this should be?
Pete.S
Post by Pete.S » Tue May 03, 2005 4:50 pm
Haven't experienced that tbh, first obvious question would be are the pressures correct? Can make a hell of a difference to wear, them just being out by a small amount....
Dalton
Post by Dalton » Tue May 03, 2005 5:56 pm
I've been quite religious in checking the tyre pressures so I don't think that could be the reason.
Another thought I had was the additional wear might be due to that scrubbing noise you seem to get when you are turning at a slow pace, recal reading a thread that this was as a result of the wheels turning at different speeds.
B6S4John
Post by B6S4John » Tue May 03, 2005 6:51 pm
Hi all. Iv'e just put the front wheels on the back and visa versa to even wear so they all need replacing together the only thing i noticed was that the outside edge of the front gets scrubbed. Your not far from me Dalton we'll have to meet up and swap notes I go to Curborough sprint course most Sundays.
John
Last one dead's a sissy.
Merlot
Post by Merlot » Tue May 03, 2005 8:19 pm
The Sport Contact 2's come with more tread in the middle by about 2mm. The fronts on S4's do wear badly on the edges esp the insides.
Maserati GranTurismo GTS Auto, S3 Sportback, TT2 3.2 Roadster, Disco3 for the heavy stuff.
Dalton
Post by Dalton » Wed May 04, 2005 9:05 am
Looks like it might just be a typical problem on the S4 then. I'll try not to worry any further.
It would be good to meet up B6S4John, I used to frequent Curborough but haven't been for some years now.
Pete.S
Post by Pete.S » Wed May 04, 2005 7:03 pm
Dalton wrote:Looks like it might just be a typical problem on the S4 then
Excessive wear on inside edges is, uneven wear isn't (in my experience, 35k miles)
Toe/camber settings?
Merlot
Post by Merlot » Wed May 04, 2005 8:14 pm
I had my 4 wheel geo checked at my Audi dealer (2 hours labour) and it was fine. Still toasted the inside of the fronts in 15k miles.
