removing numberplate
mikhailk
Post by mikhailk » Fri Feb 11, 2005 11:20 am
how do you remove a british numberplate without ripping the paint off or damaging the car? i think its glued on or something.
any advice very welcome
simple1
RE: removing numberplate
Post by simple1 » Fri Feb 11, 2005 11:36 am
Most plates are installed by the use of double sided tape........... if you pull gently, you should not damage the paint.
PhilT
RS246.com
Post by PhilT » Fri Feb 11, 2005 7:00 pm
A hair dryer helps to soften the glue.
mikhailk
Post by mikhailk » Fri Feb 11, 2005 8:25 pm
thanks for the advice. so i tried to slowly force the number plate off at one edge, and it gives, but i can see that the yellowish stuff that makes the number plate, it kind of wants to stay down, and it is just coming off the transparent bit of the plate.
i dont think i can get a hairdryer down to my car here, shall i try sticking a knife blade between the car and the plate?
teknobod
Post by teknobod » Sun Feb 13, 2005 6:58 pm
Definitely don't use the knife.
If you can't get a hair dryer to the car, I've used dental floss before now pulled to and fro behind the plate.
Andy
alastairg
Post by alastairg » Mon Feb 14, 2005 2:17 pm
Dental floss everytime. Brand does not seem to influence performance :biggrin3:
PhilT
RS246.com
Post by PhilT » Mon Feb 14, 2005 11:20 pm
If you need to remove the adhesive try cooking oil.
simple1
Post by simple1 » Tue Feb 15, 2005 7:54 am
That sounds like you are revealing more of your bedroom secrets Phil :bigblink:
Return to “General Car Chat”
Users browsing this forum: No registered users and 107 guests
