Injectors
Injectors
I'm on the verge of ordering the RS4 fuel pump and Injectors for my S4. Before I do and have to buy the adaptors for the injectors as well, does anyone know of an uprated injector that will fit straight onto a S4 ?
RE: Injectors
Hi Jeff,
Have a look at this thread
http://forums.audiworld.com/s4/msgs/1737263.phtml
You can can get so called greentop injectors which are better suited for the S4 manifold than
RS4 injectors.
HTH
Jon
RS4 injectors.
HTH
Jon
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
BRETTCOLLINS
- 5th Gear
RE: Injectors
theses are the injectors that i am running in my car.
http://www.ECSTuning.com/stage/edpd/pag ... uctID=3160
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
RE: Injectors
Did AmD do the 440cc injectors and the remap ?
RE: Injectors
Jeff, I'd seriously consider the RS4 intake manifold, throttle body along with the fuel pump and injectors if I were you. That IM flows so much more than the standard S4 unit... I'd also do the MAF while I'm in there BTW... but of course, it's down to your budget...
Cheers,
Mihnea
Cheers,
Mihnea
RE: Injectors
Mihnea
You've just listed probable £2000 worth of kit.....which doesn't even include the intercoolers!
I think I'll start with the injectors and pump ....but thanks for the info
RE: Injectors
Mihnea,
How do you match the RS4 manifold to the S4 intake ports on the heads?
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
Re: RE: Injectors
I think the heads have to be ported in order to do this...
For Jeff, I know the price of the kit I've stated, that's why I said it depends on your budget
Cheers,
mihnea
Cheers,
mihnea
JonnyX wrote:Mihnea,
Re: RE: Injectors
RS4 engine transplant definitely looks like a better option than a 'full' turbo upgrade.jeffw wrote:Mihnea
2001 Silver S4 Avant
Re: RE: Injectors
Yup, that's why I won't be going through the hassle of swapping parts over and over on my S4 engine. Take the S4 engine out, sell it or install in an old and light quattro (coupe quattro) and do a track-only car, get an RS4 engine, swap in, modify wiring so I can use an RS4 ECU (2 wires need changed) and there ya go... of course, the RS4 engine won't have stock turbos on it
cheers,
mihnea
cheers,
mihnea
Dippy wrote: RS4 engine transplant definitely looks like a better option than a 'full' turbo upgrade.
Re: RE: Injectors
Nice - you realise you will have to keep us informed about you progress on this. With loads of pics and tech chatS2tuner wrote:Yup, that's why I won't be going through the hassle of swapping parts over and over on my S4 engine. Take the S4 engine out, sell it or install in an old and light quattro (coupe quattro) and do a track-only car, get an RS4 engine, swap in, modify wiring so I can use an RS4 ECU (2 wires need changed) and there ya go... of course, the RS4 engine won't have stock turbos on it
cheers,
mihnea
Re: RE: Injectors
I will definitely do!!!!
RE: Re: RE: Injectors
...and please stay put for a few years so I know where to come for my RS4 engine transplant
Got to locate yourself an RS4 engine first......not easy or cheap. Where do they all goto??? Is there a secret RS4 graveyard somewhere?
Well I am assuming that within a few months of searching, one could be found in Germany.
I wonder what the price of a new one is?
Users browsing this forum: No registered users and 142 guests
