AMD four wheel alignment? recommendations?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
vw_nutta
Post by vw_nutta » Thu Nov 04, 2004 8:40 pm
I live in Luton, Beds. I need my s4 setting up properly on a 4wd alignment, I've seen they do it at AMD and i've been pleased with there work before.
Anyone had the same work done at AMD? Any other recommendations?
cheers
[img]modules/pnCPG/Coppermine/albums/userpics/11703/rs246_thmb_S4front.jpg[/img]
Dippy
Post by Dippy » Mon Nov 08, 2004 2:15 pm
Yes. They do a proper job and will tune your alignment for the type of driving you want. My camber is quite aggressive so that I get maximum tyre contact when cornering. Downside is that the inner edge of the tyres wears out first.
2001 Silver S4 Avant
vw_nutta
Post by vw_nutta » Mon Nov 08, 2004 8:45 pm
cool.
S4RS4
S4 Alignment
Post by S4RS4 » Mon Nov 08, 2004 9:09 pm
Dippy wrote:Yes. They do a proper job and will tune your alignment for the type of driving you want. My camber is quite aggressive so that I get maximum tyre contact when cornering. Downside is that the inner edge of the tyres wears out first.
I understand that the only way to adjust the camber is by the ride height unless you have fitted adjustable suspension links. How do AMD do this?
Prawn
Post by Prawn » Tue Nov 09, 2004 10:01 am
On the rear there is some adjustment, you can get around -1 deg, on the front no adjustment so camber is a function of the ride height. Ride height of 25.5" (65CM) from ground to wheelarch will give around -1.5~1.7 deg camber.
If you go much lower on the ride height you will start to suffer from bump steer.
Prawn
Dippy
Post by Dippy » Tue Nov 09, 2004 2:43 pm
In my case they did it at the same time as fitting the H&R coilovers (and lowering the car).
Users browsing this forum: No registered users and 175 guests
