Rumbling noise from underneath car
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
AutoUnionist
Post by AutoUnionist » Wed Sep 22, 2004 10:59 pm
My car emits what can only be described as a rumbling noise (not a whine) from about 2200 revs. I'm not sure whether it is there all the time and more noticeable at 2200 or whether it actually starts at this speed. If I dip the clutch and the car is free-wheeling I can still hear it.
The rumble appears to comes from the centre of the car beneath the rear seats. At first I thought it was just tyre noise or maybe the sound of the 4wd system but now I'm not so sure.
Paranoia is starting to set in... :shock:
Taipan
Post by Taipan » Thu Sep 23, 2004 12:14 am
Do u have standard exhaust or a modified one ?
Reason I ask : modified exhaust -like Milltek- tend to be 3-pieces vs 1-piece for the standard one (if similar to the RS4).
Modified exhaust can suffer from a small shock (like entering a steep parking entry or in a ferry) and the bolts can become loose, or worse like the parts may move away, thus the rumble (my experience on a Milltek with RS4 after a shock in a ferry).
Eric
- RS4 V6 Biturbo Imola Yellow (2001)
• Custom MTM 460hp manually tuned by Peter Link on MTM dyno at Ingolstadt HQ.
• Custom Full Milltek: Sport-Cats / Mid-Silencer: suppressed / End-Silencer: reduced.
• Full Mov'It upgrade: Front 380mm - 6 pistons / Rear 220mm - 4 pistons / Parking addon.
- Joined the Dark Side (aka. Darth Elon) circa 2013.
AutoUnionist
Post by AutoUnionist » Thu Sep 23, 2004 1:58 pm
No, its a standard exhaust. The rumble appears to be deeper pitched than the noise I would expect the exhaust system to make. Noticed one other thing...on a smooth worn tarmac road going downhill, I dipped the clutch and could hear an intemittent deep bass noise (almost like a sub-woofer) as if the axle was rubbing against something on each revolution.
Golich
Post by Golich » Fri Sep 24, 2004 1:56 pm
Only a guess, but a part of the exhaust or heat shields could be touching something causing the rumble.
