3 bar MAF
2.2 I5 20v turbo - 315 bhp
lskov
3 bar MAF
Post by lskov » Tue Sep 07, 2004 10:31 am
Does the ADU engine have a 3 bar MAF?
It seems that I cant get any more pressure than app. 1.5-1.6 bar now.
When I adjust the pressure to more than that the engine starts to run badly.... (I have upgraded exhaust, turbo etc....)
Greg_S
Post by Greg_S » Tue Sep 07, 2004 7:45 pm
have you had car remapped for new ignition timing and fuelling? if not the ECU can only compensate so much before things start going wrong.
Greg
Bullshit baffles brains
Jani
Post by Jani » Wed Sep 08, 2004 8:09 am
Yes it does have 3bar pressure sensor.
Don't know how you've upgraded the Motronic maps, would suspect the same as Greg, it runs out of fuel & ignition maps
s2driver
Post by s2driver » Sun Nov 07, 2004 12:36 am
MAF is Mass Air Flow sensor.....this doesn't have a pressure rating as it measures air speed which the ECU can determine as mass flow rate.
An RS2 has, as standard a 3 bar MAP sensor (Manifold Absolute Pressure). This is absolute pressure so can measure up to 2 bar above nominal atmospheric pressure (well theres an altitude sensor for further compensation inside the left hand A pillar).
Stock ABY S2 is 2.5bar MAP sensor and the 3B S2 has only a 2bar one.
Isklov, are you using a manual boost controller by any chance? This is not good on an S2 or RS2...be very careful. And you've upgrade turbo and exhaust too? You need a custom remap to take advantages of these changes to keep things safe/reliable and to maximise performance/economy.
1995 S2 Avant with a few mods
