Movit pads - advice required
- SimonS4MTM
- Top Gear
Hi all
Gonna need some new front pads in a few months and woudl like a bit of advice so that i am ready for when they are needed.
1. I guess there are various grades of pad available. If so, what is recomended for fast road use?
2. The car will go on the track maybe once or twice a year, is a different pad recomended and can this be used on the road without any loss in cold performance.
3. Where is the best place to buy from and how much should I expect to pay.
Thanks for your help guys!
Simon
The top of the list for me is PAGID, you can either select the Orange ones or the blue (race and rally) ones. If it´s not the best, it´s one of them.
The other possibility is to use Ferrodo or Mintex, but the word on the street is that they are not even close.
Audi Freak
Audi Freak
__________________________
Audi S4 Avant 2000 -6spd - silver -
- SimonS4MTM
- Top Gear
If fading is not a problem to you and you have a light feet, go with the orange ones.
Where are you located? cause I live in Brazil, but have a look at this links:
http://www.pagidusa.com/
- BlackShadow
- 2nd Gear
I had Movits fitted to the front of my S4 recently. I discussed with Kim at QST about the possibility of putting in on the track in the future. His answer was use Hard Pads for the track and Soft for Road. It is not the difficult to change them if you are shown how to do it. Hard pads will give much better track performance, but will give inferior road performance when cold - and it is arguable whether they really get warmed up on the road.
My S4 still has the original weedy rear brakes. Kim said these would need upgrading to avoid brake fade on the track, even with Movit 342mm fronts. Cheapest option would be reconditioned RS4 rear brakes (500 squid or thereabouts I think), expensive option is Movit (see website for prices), but they are new. Steel hoses all round as well if you don't have these.
Silver S4 Saloon
MTM Stage 4 (385 bhp), Mov'it Front Brakes, RS4 Rear Brakes, H&R Coilovers, Tanoga Shortshifter.
- BlackShadow
- 2nd Gear
I had Movits fitted to the front of my S4 recently. I discussed with Kim at QST about the possibility of putting it on the track in the future. His answer was use Hard Pads for the track and Soft for Road. It is not the difficult to change them if you are shown how to do it. Hard pads will give much better track performance, but will give inferior road performance when cold - and it is arguable whether they really get warmed up on the road.
Silver S4 Saloon
- SimonS4MTM
- Top Gear
Thanks for the info guys, i will be changing the pads myself so a second set for the track is a good idea.
I have also thought about the RS4 rear brakes for the rear, just trying to find them.
The other option i am considering is new pads on the rear, maybe Greenstuff
- BlackShadow
- 2nd Gear
- SimonS4MTM
- Top Gear
I believe so David, can someone please confirm?DavidT wrote:Simon,
Does the movit kit use the same calliper as the porsche big red ?
If so, the best ones I've had are porsche 993 TT standard pads. Quiet, good bite from cold and no track fade.
David
Users browsing this forum: No registered users and 178 guests
