uprated wastegate spring ??
2.2 I5 20v turbo - 315 bhp
DAVIDP20V
Post by DAVIDP20V » Fri May 07, 2004 3:51 pm
hello peeps.
i have just seen some uprated wastegate springs available, meant to stop boost creep. good or bad thing ??
it can only be good yea/no ?
only a tenner and easily fitted ? :wink:
Davidp20v
Rs2. Polar Silver. Was Standard 315 bhp. now with de-cats, cone filter, forge diverter valve. samcos next, then chip
Greg_S
Post by Greg_S » Sun May 09, 2004 9:34 pm
I think it helps out when your car is remapped. Most of the creep control is thru the electronic boost control tho
Bullshit baffles brains
martinjs
Post by martinjs » Mon May 10, 2004 10:12 pm
You will need your mapping altered as it will produce slightly more boost.
But should cut down on lag..i presume you mean the ones on ebay?
martin
DAVIDP20V
Post by DAVIDP20V » Tue May 11, 2004 8:44 am
Yes those ones, i ordered one anyway.
Davidp20v
Atrium
Post by Atrium » Thu May 20, 2004 11:16 pm
The boost pressure is controlled by a dedicated calculator in ECU, then changing the spring is not clever and maybe dangerous (for reliability). The spring force have to be fitted in accordance to pressure mapping of calculator and help in transition periods only!
DAVIDP20V
Post by DAVIDP20V » Fri May 21, 2004 11:14 am
so fit it when the car is about to get mapped ?
Davidp20v
alastairg
Post by alastairg » Fri May 21, 2004 4:20 pm
Not sure about this at all. Did similar on old SAAB 900 T16s but that had little ECU input c/w RS2 and still Abbott racing had to spend time to set things up.
David I found Scott at AMD very helpful over the phone and his only advice for my car @77k to ensure consistent boost was to replace the diverter valve Bosch p/n I will check if interested but same as porsche 944 turbo
Doug_RS2
Post by Doug_RS2 » Fri May 21, 2004 10:43 pm
I wouldn't play with the spring - Tuners will put in a stiffer spring and adjust the pre-tension on the spring but that should only be done along with a remap to account for it.
timucin
Post by timucin » Sat May 29, 2004 11:24 pm
i also need one; but do not have any idea about the tension should be.....is there any www for these stuff?
thnx,
Quattro
Users browsing this forum: No registered users and 31 guests
