SPEED LIMITER REMOVAL
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
mickpd
Post by mickpd » Sun Apr 25, 2004 9:03 pm
Hello all,i have just joined the fold.Can any of you technical dudes tell me how to remove (and the removal process of) the speed limiter.1996 A4 with 2002 2.7 Biturbo transplant.Thanks for any help
Dippy
Post by Dippy » Mon Apr 26, 2004 12:10 pm
AFAIK the limiting is done in the ECU, so reprogramming is needed.
2001 Silver S4 Avant
DavidT
Post by DavidT » Mon Apr 26, 2004 7:12 pm
Yep I think Dippy is right. AmD could do this I'm sure.
Unless a VAG-COM whizz knows better ?
DavidT
Post by DavidT » Mon Apr 26, 2004 7:13 pm
Welcome to the site btw.
toasty
Post by toasty » Tue Apr 27, 2004 8:20 am
I suppose also it's worth pointing out that depending on the version of the 2.7 biturbo engine, the 155mph speed limiter may not be an issue anyway.
If it's the 265bhp (S4) engine (unlikely if it's a 2002) then you might just make 160mph in it, but not much more, so it's debatable if the limiter is going to hinder you much.
If it's the 250bhp (Allroad) engine then I reckon 155 would be about the limit anyway.
If it's the 380bhp (RS4) engine then sure it's worth removing, guess that would be good for 175-180mph
If it's been chipped or tuned then same as the RS4.
I should add that when I first got my S4 I was so amazed with the performance that I thought it'd be good for 170-175mph, however the standard engine just doesn't develop any torque at high revs and that coupled with the gearing means that you get to 100 really quickly and thing that the car has loads left, however at 140 you start to feel the acceleration slowing and by 155 (160 indicated on the clock) you've pretty much hit top end.
HTH
-Dan
mickpd
Post by mickpd » Fri Apr 30, 2004 8:13 pm
Thanks for the replies lads. Ive just collected the car from AMD today.They cannot remove the limiter,but have re-mapped the ECU and fitted a massive, hybrid exhaust system,and viper D /Vs. Torque is well up now.I am impressed with final result.
Heavily modified A4+2.7 Biturbo transplant
Golich
Post by Golich » Wed May 05, 2004 8:30 pm
That's odd cos AMD removed the speed limiter (i.e. NOT the REV limiter) from my chipped S4. And I had just shy of 170mph (approx 167mph) on more than one occasion. On the track of course. :bigblink:
Interesting while the last numbers on the clock was 160mph there were further markings for 165 and 170 but no numbers.
Interestingly my RS4 will do 162mph before the speed limiter kicks in then it drops the speed to 158mph
Users browsing this forum: No registered users and 130 guests
