Don,t do what I just did....
2.2 I5 20v turbo - 315 bhp
Bluekermit930
Post by Bluekermit930 » Wed Apr 21, 2004 8:44 pm
I have been suffering from a loose horn pad on my 3 spoke steering wheel which contains the airbag. Driving me mad, mad the car feel so loose....
Had a look at it tonight and found that the frame that the hornpush is fixed to was loose. It seemed to be held by a large bolt at the 6o'clock position so, I thought I would tighten it. Got my socket set at it and got a half turn on it and then , you guessed it , it went all loose again..... bugger ! :bash:
The bolt turned out to be only a 4mm thread, despite the large 3/4"" head, and it was threaded into an aluminium frame, also about 4mm thick.
I managed to recover the situation by using a bolt with a slightly larger thread and "make" a new thread, worked very welll. I found that even when it was all tightened up, the frame was still mooving, I had to add a large spring washer and, bingo, all tight again........ :D .
So watch out if you have a go at it, my new nickname is the human torque wrench.....
Regards
Kermit
DAVIDP20V
Post by DAVIDP20V » Wed Apr 21, 2004 9:42 pm
i thought you were going to say the airbag deployed. damaging your nose and wallet ! :biggrin3:
Davidp20v
Rs2. Polar Silver. Was Standard 315 bhp. now with de-cats, cone filter, forge diverter valve. samcos next, then chip
Bluekermit930
Post by Bluekermit930 » Wed Apr 21, 2004 9:56 pm
No, got away with that, I have heard that it happens though, sttatic electrickery I think.....
First thought was I needed a new steering wheel, bad enough...
