Turbo failure?
2.7 V6 30v biturbo - 380 bhp
pat68
Turbo failure?
Post by pat68 » Tue Apr 20, 2004 1:10 pm
Hi
I'm just wondering if I have a sneaking turbo failure. I observed on the outside of the air inlet circuitry of the driver side turbo, that on the interconnections there's a slight oil film noticable. I also noticed when I was only driving very short distances and the car was standing for a day, there will be smoke for first 2-3 times the turbos spool up. If the car is warmed up, there's no smoke at all, even under full load. The car has now 60k km on the clock and is not chipped.
Patrick
JJRS4
Post by JJRS4 » Tue Apr 20, 2004 5:01 pm
So Patrick, where have you been all these years? RS4 owner presumably, and this is your first post?
Standard RS4 (is it the only standard one left?)
Bushy
Post by Bushy » Tue Apr 20, 2004 5:36 pm
Sounds like the turbos are on the way out mate, sorry
Get a stealer to check the boost pressur enad amount of oil in the intake system
Bushy
Can't beat a bit of boost!
Golich
Post by Golich » Tue Apr 20, 2004 7:03 pm
Hhmm it doesn't sound good. One thing I would say to all, is that there is always a small amount of oil present in the intake system by virtue of the crankcase breather system, which dumps small amounts of oil vapours into the intake system to clean up emmisions. So don't always assume the worst when you remove an intercooler or DV etc to find oil. It can be a reasonable coating too.
However, you should never see white/blue smoke from exhaust. This is NOT a good sign :(
pat68
Post by pat68 » Mon Apr 26, 2004 4:48 pm
Thank you for your tipps! Doesn't sound to good me. :cry:
So I will advice my dealer to take a closer lool when replacing the timing belt.
Patrick
Users browsing this forum: No registered users and 112 guests
