S2 steering vibration
Well cared for S2 coupe 111,000 miles koni dampers new tyres balanced fine vibration thru steering wheel, different speeds, improves on good surfaces to non existent
FASH recent top mount replacement
? have I a major problem ? Find I need to guide local dealer when problems appear
Yep, wishbone bushes and steering balljoints are a good place to start as James says. Also check the lower balljoints and inner seering arm bushes as the latter are simply tiny rubber bushes and mine are shot. Complete new arms from Vagparts are quite sheap too...I just bought a pair for mine.
How old are your Konis? I have known of these shocks dying after only about 35k miles on a hard-driven S2!!
It also only took me 10k miles to kill my Polyurethane bushes on the front wishbones....I blame big brakes for that!
Lee
Lee
1995 S2 Avant with a few mods
That is certainly a respectable one-day journey! A bit similar distance to my Munich to London one-day blitz...that was one expensive journey as I averaged less than 17mpg! I agree, it is hardly going to excercise the shockers much. It's the cross country B-road thrashes (sorry, I meant trackdays!) that do the damage due to the relentless steering, accelerating and braking maneouvers.alastairg wrote:Correction
Of course its been driven hard Edinburgh to Switzerland in a day springs to mind
I see you got this problem sorted with a re-balance of the rims (from your for sale thread). Did your tyre fitter need two bites at the cherry to get it right? That doesn't sound too clever!..unless you had lost a balancing weight. Not many fitters clean the rim surface of road grime before bonding new weights in place....idiots! I have lost a few in the past and now try to thoroughly clean my rims before getting new tyres to avoid the problem recurring.
Lee
