Sticky Indicators.
BlackShadow
Sticky Indicators.
Post by BlackShadow » Sun Feb 01, 2004 6:52 pm
My indicators occasionally stick. About one time in ten/twenty you indicate and the indicator just stays on and does not flash - i.e. the little green arrow just stays illuminated and there is no clicking noise. I presume from the outside you just see the orange indicator on, but not flashing.
Like I say it doesn't happen all the time. Anybody got experience of this? Is it specific to the S4 or Audis in general?
Silver S4 Saloon
MTM Stage 4 (385 bhp), Mov'it Front Brakes, RS4 Rear Brakes, H&R Coilovers, Tanoga Shortshifter.
martian
Re: Sticky Indicators.
Post by martian » Sun Feb 01, 2004 9:58 pm
Had this at New Year on the way to Cornwall- got progressively worse on the journey and after about 5 hours driving they gave up completely. Phoned Audi in Truro who diagnosed failed relay - if the hazards work then apparently it's the indicator relay only- and they had it fixed in a jif [img]images/graemlins/thumbs.gif[/img]
Best dealer response I've had , ever, from Audi, Merc or BMW.
Avus RS6
martian
Post by martian » Sun Feb 01, 2004 10:00 pm
This was'nt the case at all with my occurrence- although the indicator light was on nothing was visible outside.
Avus RS6
BlackShadow
Post by BlackShadow » Sun Feb 01, 2004 10:26 pm
No, they are definitely working outside. I just checked.
It's a 72,000 mile S4. I guess it could be that something is just starting to corrode/come loose. The car has a warranty which I guess would cover this. It's just that as the fault is intermittent, Sod's law says that if I took it to a garage, they would drive it and it would be perfectly normal.
No doubt the sands of time will mean that the problem deteriorates to the extent that it would be easier to diagnose then.
Silver S4 Saloon
peterb
Post by peterb » Mon Feb 02, 2004 11:59 am
This happened on my A6 2.7T on the Sunday morning of GTI International, last year. By the evening it had sorted itself and the problem didn't re-occur in the next 4 weeks before I traded the car for the RS6.
Suzuki Carry 660
peterb
Post by peterb » Mon Feb 02, 2004 12:00 pm
Phoned Audi in Truro ... Best dealer response I've had
Yep, it's hard to fault Carrs.
Suzuki Carry 660
JAMES
Post by JAMES » Tue Feb 03, 2004 1:24 am
i still think it could be the relay,you could change this yourself and its not expensive.its worth a try.
previous: RS2, RS4 2.7, RS4 4.2.
Current: S8 PLUS
BlackShadow
Post by BlackShadow » Thu Feb 05, 2004 1:05 pm
So, how do you change the relay then? Is this in the indicator stick?
Silver S4 Saloon
JohnW
Post by JohnW » Thu Feb 05, 2004 2:05 pm
No,
its in the fuse box.
Look inyour manual to find out where this is.
There should also be a picture which tells you which relay is which.
Either buy a new one from Audi, or read the number & type off the top of it and go get one cheaper from somewhere like Halfords.
Cheers,
John.
JAMES
Post by JAMES » Thu Feb 05, 2004 10:21 pm
if you have two relays in the fuse box of the same type you could swap them to see if it makes a difference.depending what the other relay is used for.
Current: S8 PLUS
BlackShadow
Post by BlackShadow » Fri Feb 06, 2004 5:00 pm
Thanks for your assistance guys. I shall investigate further.
Silver S4 Saloon
BlackShadow
Post by BlackShadow » Sun Feb 08, 2004 8:52 pm
I have changed the indicator relay/fuse for another 10 amp one I purchased from Halfords. This has lessened the problem - i.e. it still sticks but far less frequently since the change. So I don't think it's cured it completely. It may just be that something else has stopped the sticky indicators occuring so frequently. Anyway, I now know how easy it is to change a fuse, so that info could well come in handy in the future.
Silver S4 Saloon
JAMES
Post by JAMES » Mon Feb 16, 2004 8:14 pm
have you changed the relay and the fuse?
if so maybe there is a bad connection between the relay connector and relay,and its now slightly better.
is the old relay in as new condition,especially around the terminals?
Current: S8 PLUS
martian
Post by martian » Mon Feb 16, 2004 8:38 pm
Do the hazard lights work or do they stick?
Avus RS6
BlackShadow
Post by BlackShadow » Thu Feb 26, 2004 9:56 pm
I just changed the fuse. Is the relay the little plastic bit you stick the fuse into? This could be the next thing to change. Are they easy to change? Can you buy those from Halfords as well?
Silver S4 Saloon
Return to “Electrical”
Users browsing this forum: No registered users and 109 guests
