Faults?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
JonnyX
Faults?
Post by JonnyX » Fri Jan 30, 2004 5:56 pm
Hi Guys,
Sorry to bore you again but I am still new to the wonderful
world of S4 ownership. Anybody have any comments on the
following items: (My car is a 2000 W reg - facelift)
1) Buzzing coming from centre console - sounds electrical as
it doesn't really change with revs/vibration.
2) Rough idle - doesn't hunt but car bumps and shakes a
little.
3) turbo whine - how loud should this be? - it's quite
noticeable below 2K rpm then fades.
4) clutch engagement - pretty jerky - whats the norm?
Also, a couple of times, when I have nailed it 7K in 1st
changed to 2nd and nailed it the clutch feels like it's
slipping - new clutch required?
5) vibration in shifter - more than I was expecting.
Any other bugbears I should be looking out for?
Am I just expecting too much after upgrading from a humble
Golf MKIV?
Cheers,
Jon
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
jonno1
Re: Faults?
Post by jonno1 » Fri Jan 30, 2004 6:17 pm
Am also a new owner (2000 W facelift too) and have noticed a very slight whistle from the turbos at low revs (particularly when the engine is cold) which goes away very quickly. Is that the sort of noise you are getting? From reading the various posts this seems to be normal turbo spool noise......I hope [img]images/graemlins/grin.gif[/img]
JonS
2000 Ming Blue Avant, Tanoga Short Shift, Revo, RS4 gearbox (not by choice), RS4 Wheels, Eibach Springs, Forge DVs = Happy Days
miketheman2k
Re: Faults?
Post by miketheman2k » Sat Jan 31, 2004 12:10 am
Hi Jon,
I get almost all of what you listed on my 98 S. I think nailing it at 7k revs might be a bad idea though, try at about 3.5k revs, I think the excess power just gets burnt by the clutch and difs anyway (unless its snowing, in which case hammer it as much as you can! [img]images/graemlins/thumbs.gif[/img])
The gearchange is jerky because it is engaging 2 more wheels than normal - I've noticed a lot of the reviewers mentioned this when it was new.
Cheers,
Mike
BlackShadow
Re: Faults?
Post by BlackShadow » Sun Feb 01, 2004 7:45 pm
I think nailing it a 7k revs is a bad idea. Peak power is produced at 5,800 - 6,000. After this the power tails off. So there is no point in reving to 7k, you just go slower as a consequence. Also you are stressing components unnecessarily. Try changing up at 6k.
Silver S4 Saloon
MTM Stage 4 (385 bhp), Mov'it Front Brakes, RS4 Rear Brakes, H&R Coilovers, Tanoga Shortshifter.
