The launch
david7m
The launch
Post by david7m » Mon Jan 26, 2004 9:10 pm
Whats the best way to get my APR S3 off the lights? (traction off?)
I remember when Clarkson went out in a four whell drive car on the track, he said you have to get it rolling first with the clutch up before you can give it any, is there a quicker way?
APR 270bhp S3, Mixer K6 750
sitas3
Re: The launch
Post by sitas3 » Mon Jan 26, 2004 11:33 pm
around 3.5k revs, drop the clutch and definitely with ESP off! [img]images/graemlins/thumbs.gif[/img]
TarmacTerrorist
Re: The launch
Post by TarmacTerrorist » Mon Jan 26, 2004 11:44 pm
Oh yeah baby!!!
Too much is bad.
Plenty is better.
DavidT
Re: The launch
Post by DavidT » Mon Jan 26, 2004 11:58 pm
Can an S3 spin all four wheels in first on a dry surface ?
kiwi_mtm
Re: The launch
Post by kiwi_mtm » Tue Jan 27, 2004 6:01 am
Red line and side step the clutch with no ESP WILL be the fasted.
However, the probability of breaking something increases with RPM. Defn ESP off. You need wheelspin, even if a only little.
I saw the same Topgear show. I thought Bollocks, you have no balls boy. Recently when I went 1/4 mile'ing, I did 4 runs with 5K RPM and dropping the clutch. Mind you, i'm running standard horsepower, so the driveline should handle it.
2014 RS6 (2023 on order)
2017 Q7
1993 E36 M3 Tarmac Rally car
2001 Porsche Boxster circuit car
2017 Porsche 991.2 GT3 Clubsport
sitas3
Re: The launch
Post by sitas3 » Tue Jan 27, 2004 11:41 am
it can if you are brutal enough, however i'd not want to do it consistently!
Riz_RS4
Re: The launch
Post by Riz_RS4 » Tue Jan 27, 2004 8:44 pm
Its not too hard on the 17" AVUS alloys but on the 18" RSTT`s its alittle harder but is possible.... you`ll need high rev`s +4500rpms then dump the clutch! woooosh!
Riz [img]images/graemlins/tung2.gif[/img]
Image I`m just a hardcore petrol head :)
samtheman
Re: The launch
Post by samtheman » Tue Jan 27, 2004 8:55 pm
what about an S4? if i red lined mine and dropped the clutch, the clutch would just spin up and something would snap surely? [img]images/graemlins/burnout.gif[/img] [img]images/graemlins/033102scull_1_prv.gif[/img] sod that!! i dont need anymore expense!!
david7m
Re: The launch
Post by david7m » Wed Jan 28, 2004 9:37 pm
Is this the graph for finding optimum gear change?
smurfbus
Re: The launch
Post by smurfbus » Thu Jan 29, 2004 9:47 am
you need to measure (ap22 or vag-com) your acceleration in each gear. then look at the numbers or graph to see where they cross each other. this gives you a rpm area where you should shift.
If you shift fast it might also give you the exact rpms to shift. In my s4 it seems that even though my hp is flat in the upper rpms I need to shift early in the higher gears to get the best accelleration. from third gear on no more than 6000 rpms is best with my evotech chip.
david7m
Re: The launch
Post by david7m » Thu Jan 29, 2004 9:36 pm
Don't have VAG-COM.
Looks like i'll just be doing what feels right for the gear !
s8n
Re: The launch
Post by s8n » Wed Feb 04, 2004 12:17 am
Good post.. I have the APR S3 also [img]images/graemlins/smile.gif[/img]
I find my launching is getting better!
Audi S3
kennyboy
Re: The launch
Post by kennyboy » Wed Feb 04, 2004 9:51 am
I found it no different with ESP on or off (in the dry or wet) when dumping the clutch at 5k rpm on my old Golf 4motion on 1/4 mile sprints i.e quick get away. You have to be brutal on haldex transmission to get a good start.
I haven't tried this dumping the clutch on my RS, nor do I wish to. The haldex (part time & electronic controlled 4wd) is less worrying than on permanent mechanical quattro tranmission.
Best for me is a little roll before rock'n'roll [img]images/graemlins/biggrin3.gif[/img]
No sig, no RS4 anymore
