When is the best time to change gear?
On the APR performance graphs, max power is at 5,500 rpm, is this the best time to change gear? The limiter is about 7,200 rpm, is this the best time?
Optimum Gear Change
Optimum Gear Change
APR 270bhp S3, Mixer K6 750
Re: Optimum Gear Change
Its a combination/playoff of max power in your current gear, and also max power with the next gear. Look at a dyno chart for your engine and work out equal opposites from the peak power band by volume under the line. You'll prob' need to run past your peak power as a playoff for getting more power immediately once you've changed up.
I had this issue on my A4, with power drop off after 5k rpm. No such prob on the RS4, its just keeps climbing until cutoff!
2014 RS6 (2023 on order)
2017 Q7
1993 E36 M3 Tarmac Rally car
2001 Porsche Boxster circuit car
2017 Porsche 991.2 GT3 Clubsport
2017 Q7
Users browsing this forum: No registered users and 60 guests
