Leaking Windscreen Washer Water Bottle
General Forum for Warranty, Dealers, Servicing, Insurance, Breakdown, etc
BlackShadow
Post by BlackShadow » Tue Jan 06, 2004 2:37 pm
How easy is it to replace the windscreen washer bottle on a Audi S4 2.7? The bottle, or maybe one of the pipes from it, is leaking. I pour 4.5 litres in the top and approx 4.0 litres runs on to the road. The annoying warning sign keeps coming on, and this weather you need to use the washers frequently and they've got not a lot in them.
I'm not super gifted in the spannering department, so if its difficult, I'll take it to the Audi garage.
Silver S4 Saloon
MTM Stage 4 (385 bhp), Mov'it Front Brakes, RS4 Rear Brakes, H&R Coilovers, Tanoga Shortshifter.
wazza
Re: Leaking Windscreen Washer Water Bottle
Post by wazza » Tue Jan 06, 2004 3:46 pm
It has been spoken about before here. [img]images/graemlins/thumb.gif[/img]
Paul
BlackShadow
Post by BlackShadow » Tue Jan 06, 2004 6:32 pm
Many Thanks BiTurbo for guidance again. I'm quite impressed, this website is full of useful stuff.
Silver S4 Saloon
martian
Post by martian » Tue Jan 06, 2004 9:24 pm
Same thing happened to me but the water p***ed out from underneath the bumper- they had to remove the bumper and parktronic just to reconnect the hose (apparently) [img]images/graemlins/blush.gif[/img]
Avus RS6
BlackShadow
Audi Specialists, Burwell, Cambridge
Post by BlackShadow » Wed Jan 07, 2004 2:15 pm
Yeah, I had the inner wing off last night. It is not leaking from anywhere near the bottle or any of the connecting pipes. It is p***ing out from under the bumper. The guy at my local independent Audi garage said the pump often leaks and needs replacing, which requires taking off the front bumper/air dam thing. I shall be giving the car to them to sort that out, and my malfunctioning external heat sensor reading.
The garage concerned is Audi Specialists in Burwell, Cambs (www.audi-specialists.co.uk). Anybody got any previous experience with servicing by them? Their hourly rate is less than official Audi dealers. Those chaps seems to charge a rather steeper rate. I phoned Bishop Stortford Audi, and I'm quite suprised that the guy managed not laugh when he announced that they charge 82 squid an hour [img]images/graemlins/jawdrop.gif[/img].
Silver S4 Saloon
Carps
Re: Audi Specialists, Burwell, Cambridge
Post by Carps » Wed Jan 07, 2004 9:47 pm
Another common fault that can cause the bottle to empty is the hose on the headlamp washers comes off. This is due to the very high pressure at which they operate. I believe this can be checked and rectified without removing the bumper, so it may be worth a look at that first...
BlackShadow
Post by BlackShadow » Wed Jan 07, 2004 11:28 pm
Any idea where to look in the front bumper or under the bonnet to find this hose on the headlamp washer?
Silver S4 Saloon
Dippy
Post by Dippy » Fri Jan 09, 2004 2:14 pm
Yeah, the active search mechanism (a.k.a. Biturbo) is particularly good [img]images/graemlins/grin.gif[/img]
I'd advise you to look on AudiWorld too. The forums are rather tedious (and purile) but there's some excellent technical info there. In particular (as I implied in that other thread), the washer bottle problem is as common as muck in the US so you might find some excellent guidance information on AW.
2001 Silver S4 Avant
wazza
Post by wazza » Fri Jan 09, 2004 2:16 pm
Dave your fiver is in the post as we speak [img]images/graemlins/acclaim.gif[/img]
Paul
martian
Post by martian » Wed Jan 21, 2004 10:36 pm
I've had a little 'dispute' with my dealer over the heat sensor issue. I know it's been discussed in other threads but it would be really handy if you could give me a clue to your particular symptoms, diagnosis and remedy.
Avus RS6
BlackShadow
Post by BlackShadow » Thu Feb 26, 2004 12:42 pm
Ahh, bit of a late response here, but I did get the outside temperature sensor repaired under (independent) warranty. Basically the sensor had come loose. The dealer said it might have been cut off by the fan? Anyway, it was remounted and now it works normal. "Normal" on a S4 seems to mean that moving along the road, the outside temperature reading is fine, but stop in traffic for a while and the outside temperature reading will rise. I guess this is to be expected, given the heat being generated by the engine. If you've got a big RS6, I guess this would mean more engine heat.
Silver S4 Saloon
Return to “Audi S and RS Ownership”
