MAF to Turbo pipe
2.2 I5 20v turbo - 315 bhp
Greg_S
MAF to Turbo pipe
Post by Greg_S » Wed Nov 12, 2003 4:09 pm
Hi all,
In middle of doing a turbo upgrade etc on my S2 and trying to keep the standard airbox because it will shield better from the heat than most induction setup's. Problem i have is the MAF to turbo pipe because the new turbo has inlet dia of 70mm. where as standard is a fair bit smaller.
Ive been in touch with SFS performance for them to price up making the pipe but need to see if any interest in other people buying this pipe?
Basically it will replace the standard pipe and can be tailored to suit the turbo because they can adjust the inlet dia for the turbo.
let me know if anyone interested
Greg
Bullshit baffles brains
timucin
Re: MAF to Turbo pipe
Post by timucin » Sun Nov 16, 2003 5:05 am
are you talking about this pipe?
Quattro
Greg_S
Post by Greg_S » Sun Nov 16, 2003 1:49 pm
Yep, thats just what im after. Except without the pipe coming off for the breather because putting a catch tank setup in instead.
where did you get that?
is the turbo end dia 70mm? the MAF end do you just use a silicone 90 degree or what?
thanks
Greg
Doug_RS2
Post by Doug_RS2 » Sun Nov 16, 2003 5:31 pm
Greg - that metal pipe is what I have(mine is black though) - it is designed so you can connect the original rubber hose to it (after you chopped it in half)
I have blocked one of the holes on it. I am actually using the smaller one to connect to the diverter - it's in a more convenient position.
[img]images/rsul/32215-inlet.jpg[/img]
Doug
Greg_S
Post by Greg_S » Sun Nov 16, 2003 5:43 pm
oh right, didnt realise it was just an adaptor. How do you have it connected onto the turbo?
Doug_RS2
Post by Doug_RS2 » Sun Nov 16, 2003 6:21 pm
The turbo has a rubber o-ring on it - the adapter is a tight fit over that - it has 2 tapped holes with 2 grub screws to hold it on the turbo.
Speak to Mihnea if you are after one.
timucin
Post by timucin » Sun Nov 16, 2003 11:14 pm
http://www.totsteile.ch/
its 150 or 100 euros i dont remember exactly
in switzerlend.cool guy but doesnt speak english
Quattro
timucin
Post by timucin » Sun Nov 30, 2003 3:45 am
did you find the part?
is everything ok with your project?
Quattro
Greg_S
Post by Greg_S » Sun Nov 30, 2003 1:13 pm
I Reckon ive found a way of retaining the original pipe, and increasing its diameter so that it will fit the turbo. will take a pic once its all done.
I got in touch with tots and they wanted me to buy a turbo aswell to get the intake pipe bit [img]images/graemlins/frown.gif[/img]
Been busy fitting bits but had problems with studs for manifold so thats held me up by a day or two
timucin
Post by timucin » Sun Nov 30, 2003 4:13 pm
Good luck
[img]images/graemlins/wink.gif[/img]
Quattro
