wanted vag-com
samtheman
wanted vag-com
Post by samtheman » Wed Oct 22, 2003 11:03 pm
carps showed me his vag-com and i've just got to have one!! where can i buy one new and how much are they? [img]images/graemlins/s4addict.gif[/img]
Hopsta
Re: wanted vag-com
Post by Hopsta » Wed Oct 22, 2003 11:33 pm
You can get Vag-com from here
Always check your nuts before you have a play ! [img]images/graemlins/crazy.gif[/img]
samtheman
Re: wanted vag-com
Post by samtheman » Thu Oct 23, 2003 5:26 pm
nice one cheers matey [img]images/graemlins/thumb.gif[/img] all i need now is a decent lap top!
Taipan
Re: wanted vag-com
Post by Taipan » Thu Oct 23, 2003 6:54 pm
Then be careful with the Vag-Com version you buy.
If you take the cheaper Serial Port version (vs. the USB one), be aware that many notebooks do not have a serial port anymore.
if you go for the serial port version, Dell makes one which is a pretty good/light/decent autonomy/decent price, called the Inspiron 500m.
But for example, the cheaper/heavier Inspiron 1100 does NOT have a serial port.
Eric
PS : if you ever go for Revo, it seems their optional "advanced tuning kit" also requires a serial port as of today. You may want to verify that too. But in any case, I'd go for a notebook WITH a serial port to keep maximum options open.
- RS4 V6 Biturbo Imola Yellow (2001)
• Custom MTM 460hp manually tuned by Peter Link on MTM dyno at Ingolstadt HQ.
• Custom Full Milltek: Sport-Cats / Mid-Silencer: suppressed / End-Silencer: reduced.
• Full Mov'It upgrade: Front 380mm - 6 pistons / Rear 220mm - 4 pistons / Parking addon.
- Joined the Dark Side (aka. Darth Elon) circa 2013.
samtheman
Re: wanted vag-com
Post by samtheman » Thu Oct 23, 2003 7:08 pm
i will look out for that!! cheers [img]images/graemlins/thumb.gif[/img]
rwoodward
Re: wanted vag-com
Post by rwoodward » Fri Oct 24, 2003 10:48 am
there's always usb to serial converters - I use one on my acer laptop to talk to serial devices.. appears as a normal COM port so most software should work with it.
R
Ex '98 S4, Red, Bose
RS4 to be [img]images/graemlins/smile.gif[/img]
Mo_S3
Re: wanted vag-com
Post by Mo_S3 » Fri Oct 24, 2003 11:17 am
My laptop doesnt have a serial port and i have tried using usb to serial convertors and unfortunately the Vag com does not work with these converters unless u buy the very expensive one.
DavidT
Re: wanted vag-com
Post by DavidT » Fri Oct 24, 2003 11:30 am
There's some info in Ross-Tech's FAQ here
