Dear all,
What are the recommended tyre pressures for a RS2 running the 245 width
tyre?
Also,
When I track around left hand corners and when I go slowly after braking I get a kind of medium pitched metallic grinding noise occasionally from the rear. Must I conclude that a wheel bearing needs replaced? Or might it be something else?
The car hasn't been driven for a month or two, and I've just had the rear brake pads and rear tyres replaced....
Thanks again.
Regards,
Mark.
Noise and Tyre pressures?
- markcanderson
- 2nd Gear
'94 Audi RS2 Avant (Polar Silver)
'01 Saab 9-3 TiD S Coupe. (Abbott tuned)
Re: Noise and Tyre pressures?
tyre pressure in summer driving should be around 39 psi ! according to inside the fuel flap. [img]images/graemlins/nodder.gif[/img]
i also get scrubbing from the rear tyres, mainly when going over speed bumps, [img]images/graemlins/033102bad_1_prv.gif[/img] i now have realised this is because the tyres i had fitted are too wide, [img]images/graemlins/033102bad_1_prv.gif[/img] i should have downsized 225 according to some previous posts which is one of the next things to do. [img]images/graemlins/062802beat_prv.gif[/img]
Davidp20v
Rs2. Polar Silver. Was Standard 315 bhp. now with de-cats, cone filter, forge diverter valve. samcos next, then chip
oh yea, check under the arch where the rear bumper is and inner arch for scrape marks/tyre marks. [img]images/graemlins/thumbs.gif[/img]
Davidp20v
