EVAP help please
5.0 V10 50v biturbo - 571 bhp
Spindle
EVAP help please
Post by Spindle » Tue May 06, 2025 11:24 am
We bought our RS6 in October and it is a lovely car with only one fault - P0441 EVAP Emission control 002 incorrect flow intermittent.
The guy we bought it from had already replaced the N80 and made us aware of the fault saying he thinks it is the charcoal canister. The car runs fine, just the annoying light on the dash.
Skip forward a bit, and I have been putting some time aside to drive it to work and investigate the cause of the fault. I found he had replaced the N80 with a non genuine one and had forced the original one out of the pipework leaving damage to it. I have replaced the valve and the pipework with brand new genuine Audi parts and while I had the old one off I tested it and it does not hold vacuum where the new one does. BINGO I thought! Swapped the new part and hoses in, cleared the code with VCDS and drove it home which is an hours drive. Light stayed off.
Drove it back to work the next day, another hours drive and the light pinged up just as I pulled into my carpark :audibash:
So on to the next component - charcoal canister. This absolutely stank of fuel and was really heavy so I fitted a brand new one, again genuine Audi part. Cleared the code, drove home, light stayed off. Then on our drive to Cadwell Park the light came back on again :audibash:
Now as far as I can see from diagrams the rest of the system is fairly simple pipework.
I need to check all of this as well as the fuel cap.
I am trying to eliminate everything by testing it and replacing it if there is the slightest hint of fault but my question is has anyone been through this saga with theirs and what did you find was the cause please? As much as I enjoy driving it to work and spending time on my own car instead of customers cars it is not very profitable so I'd like to get to the bottom of it sooner rather than later.
Any advice on what and how to test parts of the system are welcome!
On the hunt for an RS6 C6....
IanH755
Re: EVAP help please
Post by IanH755 » Tue May 06, 2025 10:17 pm
There's literally just 4 things in the system, the fuel cap, the N80 valve, the carbon canister and the pipework, so having replaced everything else so far maybe look at the fuel cap or maybe a pipe/connection has rusted/split.
To find a split etc you could try a vacuum test at the canister end as the N80 should be blocked if its working correctly and provide something to "suck" against, to see if there's a pipework leak at least.
Spindle
Post by Spindle » Wed May 07, 2025 1:04 pm
This is my thinking too, I'm going to get a new fuel cap partly to eliminate it from the system and partly because the little rubber thing that attaches it to the car is all twisted and irritating to look at so it might solve two issues!
I'll have to check the hoses as the next actual job.
Thanks for the suggestions, when I solve it I'll update the thread so it has an end and solution - too many problem threads never post the answer!
Spindle
Post by Spindle » Fri Jul 25, 2025 2:35 pm
I am still trying to fix this issue (fuel cap seal did not fix the problem) and have tested the N80 valve with an external power supply and can hear the valve opening and closing but one thing I have noticed is that the two wires going to the valve have been cut and replaced with different colours.
Can someone do me a favour and look at the plug and wires on their N80 valve and tell me which colour wire goes to which side of the plug please? I can not find it anywhere online. The wire colours have either a blue trace or a violet trace. This will help me make sure whoever re did the wires did not manage to switch them round.
I am starting to think it is an issue with the ecm as when trying to carry out a test via VCDS it just says it is not able to....
Jim Haseltine
Post by Jim Haseltine » Fri Jul 25, 2025 10:15 pm
According to the ElsaWin schematics, the lilac tracer goes to pin 2 and the blue to pin 1, usually the pin numbers are moulded somewhere on the multi-plug.
Spindle
Post by Spindle » Tue Jul 29, 2025 9:41 am
Thank you for your reply, I did manage to find a wiring diagram in the end and checked them - they were correct although I don't like the wire they used so I will likely be swapping it for the correct gauge and type.
I am beginning to think it is a module issue as I can not find a fault with an of the EVAP system so far.
