HELP NEEDED 004
GWGRS4
HELP NEEDED 004
Post by GWGRS4 » Thu Sep 12, 2024 6:08 pm
Hi guys , own a B5 rs4
Went back to her after 11 years wouldn’t start
Got to bottom fuel tank pipes had broken to bits so replaced all them with a Bosch 044 genuine pump.
Now the connector isn’t showing any power that plugs on the pump
Checked the fuses on side panel and under drivers ?
Could anyone recommend a decent close by mechanic, located in Halifax West Yorkshire
brutus03
Re: HELP NEEDED 004
Post by brutus03 » Fri Sep 13, 2024 8:56 pm
Hi there! Sounds like you’re dealing with a frustrating issue—it's great that you’ve already replaced the fuel tank pipes and pump. If there’s no power at the pump connector, it might be worth checking the fuel pump relay, as it could be the culprit. Also, double-check the ground connections and ensure there’s no corrosion affecting the electrical circuit.
thedonman
Re: HELP NEEDED 004
Post by thedonman » Fri Oct 25, 2024 4:57 am
Hmm. Definitely worth getting a specialist to look at it after sitting so long.
Return to “General Car Chat”
