Hi
Just joined here need some guidance on how to get these crazy list of faults resolved
the steering rack needs basic settings but wont set when doing end to end learning and there are issues on BA mounts which also resolving hope some can shed light on how to get these erased
I need a new headlight height sensor for passenger side the car needs new seat belts but not sure which ones need replcing
below is a VCDS log read out anyone that can figure this out ?
I have edited my VIN>
Tuesday,20,February,2024,01:31:14:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0
Data version: 20140822
VIN: WUAZZZ4GXENXXXXXX License Plate: RS6
Mileage: 24176 Repair Order: rs6 avant
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 0E 10 14 15 16 17 19 1B 20 22 28 36 3B 42
44 46 47 52 53 55 56 57 5F 62 65 6D 72 82 BA
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1B-Active Steering -- Status: Malfunction 0010
20-High Beam Assist. -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
82-Heads Up Display -- Status: OK 0000
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CRDB) Labels: None
Part No SW: 4G0 906 560 HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0009
Revision: NCH62---
Coding: 122A00326526130A1000
Shop #: WSC 00477 128 28888
ASAM Dataset: EV_ECM40TFS0114G0906560 001010
ROD: EV_ECM40TFS0114G0906560.rod
VCID: E5C747CFE4E3943688B-80B0
7 Faults Found:
4332 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [167] - -
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 38908 km
Date: 2024.02.20
Time: 00:53:53
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 38908 km
Date: 2024.02.20
Time: 00:53:53
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 38908 km
Date: 2024.02.20
Time: 00:53:53
7036 - Thermostat for Mapped Engine Cooling (F265)
P0597 00 [039] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 38908 km
Date: 2024.02.20
Time: 00:53:53
17875 - Exhaust Pressure Control Valve
P0475 00 [039] - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 38908 km
Date: 2024.02.20
Time: 00:53:53
17876 - Exhaust Pressure Control Valve 2
P049F 00 [039] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 38908 km
Date: 2024.02.20
Time: 00:53:53
12352 - Coolant Pump for Intercooler
P023A 00 [039] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 38908 km
Date: 2024.02.20
Time: 00:53:54
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4G0 927 158 BD HW: 0BK 927 156 AM
Component: 0BK 40TFSIRdW H16 1001
Revision: --H16---
Coding: 000001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_AU57.rod
VCID: 71EFA39FA02BC896643-8024
No fault code found.
Address 03: ABS Brakes (J104) Labels: 4G0-907-379.clb
Part No SW: 4G0 907 379 P HW: 4G0 907 379 P
Component: ESP PREMIUM H09 0100
Revision: -------- Serial number: --------------
Coding: 84BF890121FD9180CB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004036
ROD: EV_ESPPremiAU57X.rod
VCID: 3E7548A3A1F567EEA91-806B
3 Faults Found:
0859 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:39:52
0486 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:39:51
0732 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:39:51
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 CT HW: 4H0 907 064 CT
Component: BCM2 2.0 H33 0433
Revision: 00002001
Coding: 05B92F07000000000000
VCID: 7DF78FAFE473BCF6F0B-8028
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
Component: KLIMA 4 ZONEN H13 0087
Serial number: 20061300041261
Coding: 6822607819
ASAM Dataset: EV_AirCondiComfoUDS 002040
ROD: EV_AirCondiComfoUDS.rod
VCID: 62CDDCD375CD630EED9-8037
11 Faults Found:
0231 - Supply Voltage for External Components
B10BD 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
0243 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:49
0245 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
0291 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:51
0314 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:54
0327 - Sunlight Photo Sensor
B10E8 14 [009] - Open or Short to Ground
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
0387 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:49
0392 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
0400 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
0401 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
0517 - Sunlight Photo Sensor
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001742418
Coding: 0907200109749FF0318100C7A0001800CF91C7082F080201800108546F01
VCID: 6FEBA5E7BE1FDE66727-803A
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A
Component: WWS57X 130618 H36 0080
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BG HW: 4G0 941 531 BG
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Coding: 110000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Coding: 020300
2 Faults Found:
03020 - Local databus 2
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Time Indication: 0
Date: 2024.02.20
Time: 00:40:00
01229 - A/C Humidity Sensor (G260)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Time Indication: 0
Date: 2024.02.20
Time: 00:40:00
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
Coding: 010000
VCID: 234399D722572A06A6F-8076
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AC HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0091
Revision: 11001001 Serial number: 61031317601973
Coding: A8C31B
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000.rod
VCID: 73E3A997DA37FA8696F-8026
1 Fault Found:
13679386 - Databus
U1123 00 [009] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
Address 14: Susp. Elect. Labels: None
Part No SW: 4G0 907 376 HW: 4G0 907 376 A
Component: J250 DRC FahrwerH01 0040
Revision: 00000000 Serial number: 00894015032200
Coding: 0000000
VCID: EBD331F7CA07A246DEF-80BE
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00DUNEW
Coding: 30323436313330303534554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3665508389C5AFAE711-8063
Crash sensor for side airbag; driver side:
Serial number: 3575HRB401050HLEJ8NF
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB400A50I7E8I0V
Crash sensor for side airbag; rear driver side:
Serial number: 3515JRB401I50J2AKHC7
Crash sensor for side airbag; rear passenger side:
Serial number: 3525JRB400450ITUDH4O
Crash sensor for front airbag; driver side:
Serial number: 3554VRB405531BAME0A%
Crash sensor for front airbag; passenger side:
Serial number: 3564VRB406131QKE3OHY
4 Faults Found:
9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [137] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:51
9442331 - Passenger's Belt Force Limiter Igniter
B1014 1B [137] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:51
9438746 - Igniter for Seat Belt Tensioner; Driver's Side
B1006 1A [137] - Resistance Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:51
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [137] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:51
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372MGO000LP
Coding: 0004FC
Shop #: WSC 67927 787 00104
VCID: 38795EBB8BD159DE63D-806D
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Component: E221 - MFL H08 0010
1 Fault Found:
01747 - Sensor for Heated Steering Wheel (Z36)
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Time Indication: 0
Date: 2024.02.20
Time: 00:31:45
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G0 920 931 A HW: 4G0 920 931 A
Component: TBenRdw Nv H80 0618
Revision: 30460230 Serial number: 658120613596004
Coding: 23AF110BABC1A600010400
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 24419ACB2F592D3EDF5-8071
1 Fault Found:
1048578 - No Basic Setting
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:32:30
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000991498
Coding: 00E5074800
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPkoUDS.rod
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 7250930603
Voltage stabilizer:
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 L HW: 8K0 907 144 L
Component: DYNAMIKLENK. H06 0720
Revision: 52001005 Serial number: --------------
Coding: 010100
1 Fault Found:
01087 - Basic Setting Not Performed
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Count: 56
Count: 1
Hex Value: 0x0076
Hex Value: 0x781A
Hex Value: 0x0B00
Hex Value: 0xFBFF
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 7CF182ABFF69B5FEC75-8029
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0200
Serial number: 001706130001430
ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
ROD: EV_AllWheelDiffeQSPFR.rod
VCID: 28598EFB5371C95EF3D-807D
3 Faults Found:
0121 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 01:07:48
0122 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 01:07:48
0377 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 01:07:48
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 J HW: 4G0 919 158 J
Component: KLIMA FOND H07 0087
Serial number: 28061300040990
Coding: 22
ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
ROD: EV_ClimaContrUnitRearUDS.rod
5 Faults Found:
0036 - Motor for Rear Right Upper Body Vent
B10D4 31 [009] - No Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:32:11
0068 - Position Sensor in Rear Left Upper Body Vent
B10E5 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
0070 - Position Sensor in Rear Right Upper Body Vent
B10E6 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
0094 - No Basic Setting
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
0112 - Motor for Rear Left Upper Body Vent
B10D3 31 [009] - No Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:32:11
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000062433396
Coding: 00781B0000006001000001010101102030303232203232
VCID: F7FB1D87464F16A62A7-80A2
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H02 0056
Revision: -------- Serial number: EJ1BPA7E00J9BB
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_AU57.rod
VCID: 377B5D878ECF56A66A7-8062
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F16005E01620002080002
VCID: 479B2D47F62F26261A7-8012
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000878575
Coding: 101000010000
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS.rod
VCID: 3A7D44B3BDDD4BCE959-806F
2 Faults Found:
5258753 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:46
4215041 - Control Module
C109F 00 [137] - Incorrect Version Installed
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:46
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0310173310
Coding: 017E1E62A0B9309D83B00984000312450000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J245 PS20.008 H02 0007
Coding: 901E00
Subsystem 4 - Part No SW: 4G0 947 135 K HW: 4G0 947 135
Component: Dachelektroni H10 0100
Coding: 010000
Subsystem 5 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J394 PS20.008 H02 0007
Coding: 801E00
Subsystem 6 - Part No SW: 3AA 962 243 B HW: 3AA 962 243 B
Component: GEB.F.Heckoef H16 0810
3 Faults Found:
03974 - Sensor for Rear Lid/Hatch Opening
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Time Indication: 0
Date: 2024.02.20
Time: 00:48:52
02906 - Control Module for Sliding Roof; Rear (J392)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Time Indication: 0
Date: 2024.02.20
Time: 00:48:52
00230 - Transmission Park Selector Switch (F305)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Time Indication: 0
Date: 2024.02.20
Time: 00:49:49
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000010168
Coding: 030000
VCID: 1D37AF2F04331CF690B-8048
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0507
VCID: 46852043F1253F2EE11-8013
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000738463
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 2C5172EB4789E57E175-8079
1 Fault Found:
262656 - No Basic Setting
B2010 00 [137] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 38593 km
Date: 2023.08.14
Time: 20:01:05
Address 55: Xenon Range (J431) Labels: None
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 130621-0002-253
Coding: 1122A6601000B300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 2D577FEF7C93EC7600B-8078
1 Fault Found:
392714 - Positioning Motor for Headlight Range Left
C1085 15 [137] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:46
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109F20D7687660
Coding: 040103010000000001
VCID: 2D577FEF7493EC7600B-8078
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4G0 919 129 C HW: 4G0 919 129
Component: NGTV-DVB H04 0690
Revision: R0043000 Serial number: 06801300578401
Coding: 07000000
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 764 K HW: 4G0 035 764 H
Component: H-BNT-RW H51 1072
Revision: -------- Serial number: 192FP0D7504011
Coding: 070101010303C5FF6780DF3E000000035C0001000100000000
VCID: 2F6B65E77E9F9E66327-807A
Subsystem 1 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Subsystem 2 - Part No SW: 4G2 919 612 Q HW: 4G2 919 612 Q
Component: E380 BDT C7 H11 0204
Subsystem 3 - Part No: 8R0 060 961 F
Component: CD-Database 5298
4 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Time Indication: 0
Date: 2024.02.20
Time: 00:31:49
Freeze Frame:
Text: NGTV_DVB,H6X,M,0,0,6
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 191
Mileage: 38908 km
Time Indication: 0
Date: 2024.02.20
Time: 00:31:50
Freeze Frame:
Bin. Bits: 00001000 00000000
Bin. Bits: 00000000 00000000
01043 - Control Module; Incorrect Software Version
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Time Indication: 0
Date: 2024.02.20
Time: 00:32:00
Freeze Frame:
Bin. Bits: 00000000 00000010
03675 - Navigation Data Not Present
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Time Indication: 0
Date: 2024.02.20
Time: 00:31:48
Freeze Frame:
Voltage: 12.00 V
Address 62: Door, Rear Left Labels: None
VCID: 55A7F70FBC8384B698B-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 4H0 907 273 HW: 4H0 907 273
Component: RDKBERU25 H09 0700
Serial number: 10000000003292
ASAM Dataset: EV_RDKBERU25 003014
ROD: EV_RDKBERU25_AU57.rod
VCID: E8D94EFB13F1895EB3D-80BD
5 Faults Found:
12652551 - Tire Pressure Monitoring
C10DC 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
8392963 - TPMS Transceiver in Front Left Wheel Well
C104C 04 [008] - Internal System Fault
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 231
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:57
8393219 - TPMS Transceiver in Front Right Wheel Well
C104D 04 [008] - Internal System Fault
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 231
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:56
8393475 - TPMS Transceiver in Rear Left Wheel Well
C104E 04 [008] - Internal System Fault
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 231
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:56
8393731 - TPMS Transceiver in Rear Right Wheel Well
C104F 04 [008] - Internal System Fault
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 231
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:57
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 165300738
Coding: 097205C010
ASAM Dataset: EV_HDSGAu572 001022
ROD: EV_HDSGAu571_AU57.rod
VCID: 3567578F94C3A4B678B-8060
1 Fault Found:
0114 - Load Space Cover
B12EF 54 [137] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
Address 72: Door, Rear Right (J389) Labels: None
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HR H03 0507
Coding: 010F14004001620002080002
VCID: 499F2B7FE03BD0560C3-801C
Address 82: Heads Up Display (J898) Labels: 4G0-919-604.clb
Part No SW: 4G0 919 604 L HW: 4G0 919 604 L
Component: HeadUpDisplay 004 0201
Revision: 00000000 Serial number: 00000000000000
Coding: A20000
ASAM Dataset: EV_HUDContiC7 001023
ROD: EV_HUDContiC7.rod
VCID: 34616A8B9FB9BDBE4F5-8061
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H05 0006
Revision: 00001001 Serial number: 97804002126804
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X.rod
VCID: E6C540C319E59F2E811-80B3
6 Faults Found:
0291 - Signal Line for Sensor 1 for Drivetrain Mounts
C112F 11 [009] - Short to Ground
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
0554 - No Basic Setting
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
1291 - Extended Diagnostic Scope
P193D 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:48
1632 - invalid data record
B2005 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:45
1293 - Actuator 2 for Drivetrain Mounts
C1132 07 [009] - Mechanical Failure
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:48
1295 - Drivetran Mounting
C1154 02 [009] - Signal Failure
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 191
Mileage: 38908 km
Date: 2024.02.20
Time: 00:31:48
End ---------------------------------------------------------------------
C7 RS6 faults help
luciocarlos
Re: C7 RS6 faults help
Hi, it's been around 9 months later. Were you able to find any solutions to clear these faults and get the steering rack to set correctly?
