leak from transmission cooler pipe
markmark
Post by markmark » Sat Feb 17, 2024 12:04 am
I have leaks from the place marked in red. The engine and gearbox are installed in the car. Do you know if it will be possible to remove the left gearbox leg without disassembling the engine to easily access these tubes? I wonder if the turbo/downpipe will interfere with unscrewing the gearbox mounting
https://i.ibb.co/DgVz1yx/gag.png
Mɐʇʇ
Re: leak from transmission cooler pipe
Post by Mɐʇʇ » Sat Feb 17, 2024 11:25 am
Maybe. There is a DIY guide on here for replacing that selector switch you can see in your photo without removing the engine, that might give you enough clearance?
http://forum.rs246.com/viewtopic.php?f=2&t=116756
