Injector fault
5.0 V10 50v biturbo - 571 bhp
Newb
Injector fault
Post by Newb » Tue Jan 30, 2024 11:04 am
Good morning everyone, its been a while.
last time i posted about an engine drop and all's well in that regard.
the new challenge is that cylinder #6 is not partaking in the festival of explosions that keeps us going forward at a steady pace.
all faults point towards it's injector, which means that i will be checking the injector and all cables involved.
in case it IS the injector, do i replace only #6 or do i replace all 10?
in case its cable issues... what part would i need to replace.
looking forward to hearing from you all!
Jim Haseltine
Re: Injector fault
Post by Jim Haseltine » Tue Jan 30, 2024 11:52 am
If it's the injector it depends on how old the set is. If they're all the originals then best to replace the lot - it's amazing how bad they can be without appearing to effect the way the engine runs.
If it's wiring then you need a good autoelectrician to pin-point the fault and possibly perform a cut and splice repair. I believe that the loom for the left side injectors is more complex than that for the right.
Newb
Re: Injector fault
Post by Newb » Tue Jan 30, 2024 2:51 pm
i was also wondering if this could help prevent it from happening again and at what interval (if any) it should be used:
additive/cleaner: G001780M3 / G001770A2
i really hope its jus this one unit thats faulty, thankfully i do know a very experienced autoelectrician but eh, those jobs take time..
Users browsing this forum: No registered users and 224 guests
