Oil Cooler and Hose Supplier
lugars4
Post by lugars4 » Sun Oct 29, 2023 3:05 pm
Anyone tried these guys?
https://www.greenon.uk/shop
06 - B7 RS4 Saloon - Milltek Non-Res Valved. BMC Filter.
12th
Re: Oil Cooler and Hose Supplier
Post by 12th » Mon Oct 30, 2023 9:12 am
I haven't, but as posted elsewhere the Forge item seems to be the default choice.
KNN
Post by KNN » Fri Apr 05, 2024 8:10 pm
Go with Forge, unless you want to try and share with us your experience.
coffey555
Post by coffey555 » Sat Apr 06, 2024 3:24 pm
The Forge kit works but is far from ideal. The cooler is actually mounted in the upside down position. It is also mounted higher up than the OEM one so the oil pump has to work harder.
Care needs to be taken when installing as they can produce a weird harmonic around 1800rpm.
My one also rubbed against the main radiator which then need replacement. Not Forge's fault, just an error by the Indy. The hoses can also chaff against one of the front mounting brackets.
An OEM cooler (or Radtec one) paired with either original hoses or JHM ones is what some good Indy's are recommending these days.
Having said that, my Forge setup has lasted 10 years! Just a bit crusty now....
Misano Red RS4 B7 Avant
JRC1
Post by JRC1 » Sat Apr 06, 2024 7:26 pm
The Forge kit isn't great as per all of the reasons coffey has outlined above. It certainly isn't the default choice. I would say 75% of people on the FB group and other forums go for Radtec with OE or aftermarket lines.
Users browsing this forum: 666Lenine, vailpilgrim and 92 guests
